laptop as a squeezebox remote
0 Members and 1 Guest are viewing this topic. Read 1216 times.
rtate
« on: 23 May 2009, 01:45 am »
I just got a laptop and I would like to use it as a remote control for my squeezebox.
Is there a "how-to" around somewhere that I can use??
mcgsxr
Re: laptop as a squeezebox remote
« Reply #1 on: 23 May 2009, 02:00 am »
I hope it is going well rtate!
http://www.audiocircle.com/index.php?topic=61597.0 - this is a thread that I started, when I was looking for ideas on how to get my wifi Blackberry Bold to control my SB3.
mgalusha points out how to enter the IP address of your SB3 into a browser, and make it happen.
It will work for your laptop too.
All the best,
ted_b
« Reply #2 on: 23 May 2009, 02:10 am »
Just point your laptop web browser to SqueezeCenter GUI.  It's just like you would if you pointed a Nokia or anything else at it, except no need for emulation or skin cuz you have a normal laptop.  It's found by knowing the IP address of your loaded SC (probably 192.168.1.something, then adding "colon 9000" i.e :9000 )
