0 Members and 1 Guest are viewing this topic. Read 5321 times.
That is odd, if it hits the internet via wifi it should be able to hit the slim server. Do you get the same results using the server IP Randy?
I can connect to my wifi at home, and can surf the external net on my Bold.I can connect to my wife with my work notebook, and can remotely control my SB3 with my notebook.When I try to connect to my SB3 using the Bold, I get an error - HTTP Error 400: Bad RequestI am entering the handheld link from above.
Likely simple, but I am not sure where to find the General Properties page.What menu is it under?
Thanks Randy, I am getting closer...I have been able to select the equivalent (called HotSpot Browser on my unit), and I can connect to http://server:9000The REALLY odd part, is that I STILL cannot connect if I add the /handset to the end.And while connected to the server, all I can see is a white rectangle where all the information should be.Since I can connect, I will try playing around with switching to Firefox, or IE rather than Blackberry and see what happens.Sure is a funny one!Thanks for all the help, when the next person has to do it, the path sure will be well marked!
