EAC setting question
0 Members and 1 Guest are viewing this topic. Read 1006 times.
rtate
« on: 8 May 2009, 03:21 pm »
Is it best to use "test and copy" when ripping my cd's
or is it ok to just "copy"?
When I look at the copy results the is something that says "peak"
what does this number mean??
It always seems to be less than 100, usually around 94%
Is this something to be concerned about?
Bob in St. Louis
Re: EAC setting question
« Reply #1 on: 9 May 2009, 04:21 pm »
You'll want to "copy selected tracks". Then "copy compressed".
I wouldn't worry about the %.
Someone else may be able to explain better. Honestly I can't recall what than number is, but do recall being told that a number in the '90s is fine.
Bob
