0 Members and 1 Guest are viewing this topic. Read 5907 times.
the right speaker is a bit closer to the wall then the left one ... I have had the damndest time getting the imaging to be centered
I know that bass will collect in the corners, but I'm wondering if there is any way to pull more of the bass out toward the listening chair so I could hear it better.
So do these bass traps help to bring the bass more out front, or just kill the bass in the corners?
Quote from: theclipper on 2 May 2009, 06:34 pmSo do these bass traps help to bring the bass more out front, or just kill the bass in the corners?Bass traps make the bass more even all around the room. Peaks go down, nulls come up (your main problem), and ringing is also reduced. Ringing is responsible for the boomy sounding effect commonly known as "one note bass," where all the bass notes sound more or less the same. In small rooms, the most common problem is usually a lack of bass where you listen. The bass comes out of your speakers just fine! But it gets reduced where you sit due to reflections combining in the air out of phase with the direct sound from the speakers.--Ethan
With a room as small as mine how big of bass traps do you think I would need?
would these go in the corners behind the speakers?
is it a big deal that the corner behind the right speaker juts out about 4 inches?
Would bass traps help to reduce the amount of noise that makes its way to the floor above?
Can too many bass traps make the room too dead?
