0 Members and 1 Guest are viewing this topic. Read 9807 times.
Hi 45, I think, yes, amount of energy lost is in any case minimal, but let's inquire into what aspect of cone movement this energy loss might affect. It would seem to me acceleration would be the primary compromised element, and more so the higher the acceleration. This compromise would seem to me to compromise transients.
In what way will the diaphragm lose energy? Remember that for SPL to be compromised, the diaphragm's acceleration relative to "space", or ground, must drop.
What an interesting subject. I followed the timedomain links (interesting English) and what is mentioned there makes perfect sense to me; Separating the loudspeaker ground from the enclosure. After all, that’s what we do with amps, separating signal ground from chassis ground.Any action will result in an equal opposite reaction. The action would be the loudspeakermembrane and the reaction the loudspeaker chassis+enclosure. Expressed in grammes, the difference is huge. But what if we use logaritms like we do for voltage, then the numbers appear less favorably.Let Mm be the moving mass of the system and Ms the stationary mass of the system. Then we could define the mass ratio dBM as 20 x log(Ms/Mm). For the Fostext208∑ the equivalent moving mass is 12g, the stationary mass is 3800g. The mass ratio would then be 50.0dBM, and the Fostex has a very low moving mass and very heavy magnet system. A typical loudspeaker has a higher moving mass and much lower magnet system weight, so 50dBM is already on the high end of the scale.Does this make any sense? I mean, could this dBM number be used to predict the amount of cabinet resonances? A sort of signal to cabinet energy ratio?
Quote from: 454Casull on 26 Apr 2009, 07:33 pmIn what way will the diaphragm lose energy? Remember that for SPL to be compromised, the diaphragm's acceleration relative to "space", or ground, must drop.To the extent the magnet/basket assembly, and with this, anything to which it is attached (baffle, etc.), moves or vibrates has the diaphragm lost energy. When the cone is propelled forward, the magnet assembly is propelled back. Any resulting movement back subtracts from cone movement forward, meaning the cone moves less relative to air. Transients would thus be compromised.
45, language like "should not allow the motor to move significantly" is not sufficiently precise for me. I'm here wondering to what degree music is affected by just those kinds of movements. My questioning wants better to understand what movement is or might be there and what aspect of sound is or might be affected by that movement. If my questions are irrelevant, then they're irrelevant. I'm not convinced they are. The difference between a good and a great speaker is found, IMO, in those kinds of details.
EDIT: By the way Mark, welcome to the Hawthorne club. aa
