Max length of Coax Digital Cable?
0 Members and 1 Guest are viewing this topic. Read 3446 times.
John Casler
« on: 25 Apr 2009, 09:23 pm »
I am considering running a LONG (15-20ft) coax digital cable from my VUDU (which has Pandora Internet Radio) to my BP26DA digital input on my 2 channel rig.
I have already tried said length connection using a "cheap" video cable and found it horrible compared to running a shorter "optical" digital cable to my HT set up which uses the same speakers (VMPS RM40s) and sounds GREAT :thumb:
The short Optical run is clear and clean sounding (as much as Internet radio quality can be) but the longer run is AM Radio quality only if that.
The optical cable is 1m.
Optical is not an option with the BRYSTON internal DAC Card since it only accepts coax digital.
Don't really want to spend the money if the length is the problem and not the fact that I used a "cheap" video cable.
Anyone have any thoughts about perfromance limits at that length?  As an AudioQuest Dealer I can afford to get a reasonably good quality VDM-5 (100% pure silver) cable.
whubbard
Re: Max length of Coax Digital Cable?
« Reply #1 on: 25 Apr 2009, 11:02 pm »
Well,
The cheap cable could have something to do with it.
TV signals can run perfectly over Coax for 20ft without any sorts of problems, I've just never tried audio that long.
Seem like you should really just keep it under 10m, which is what your doing:
http://www.epanorama.net/documents/audio/spdif.html
-West
jhm731
« Reply #2 on: 26 Apr 2009, 01:57 am »
I use a 5 meter Analog Research-Technology U-Byte cable between my Squeezebox Duet and digital processor.
Sounds as good as any shorter digital cable I've tried.
John Casler
« Reply #3 on: 26 Apr 2009, 04:00 pm »
Sounds like it whould work then.
art
    • Analog Research-Technology
John Casler
« Reply #5 on: 30 Apr 2009, 01:31 am »
http://www.audiocircle.com/index.php?topic=60136.msg535663#msg535663
Pat
Thanks Pat,
One of your fans already pointed me in that direction, but I am stuck with using a "credit" from another manufacturer.
art
« Reply #6 on: 30 Apr 2009, 02:59 am »
That's fine. Just pointing out that we routinely run a 60' cable from the "lab" area to the main listening room.
Pat
