0 Members and 1 Guest are viewing this topic. Read 10972 times.
Where can I get one of those I have been wanting to build a cmoy but have never done it.Thanks
Hey Ed,Are you going to use an Altoids can or something from Ratshack? Paul
That be the one. I tired to past the link in the normal way and it kept pasting itself on three lines and not showing up. ED
Hello, i bought the same kit and had the same problem (sound in the left channel only), could you tell me where is the missing strap ? A picture would be perfect (i'm not good in electronic, i'm not good enough in english )Thank you
Thank you for your quick and detailed answer, i did it but it still not working Sounds comes only in left ear.
I'm afraid it's a lost cause now, i tried wriggling, nothing, i check the solder, nothing, and now, i blew the pcb with soldering/desoldering components.It was my first DIY project (in audio), it won't be the last even if this one was a failure.Thank you for your timewiget
Ed,Is this through-hole construction or SMT?-- Jim
