0 Members and 1 Guest are viewing this topic. Read 14325 times.
Quote from: Nuance on 16 Apr 2009, 12:55 pmQuote from: rahimlee54 on 16 Apr 2009, 11:10 amShould I be trying to get a DAC and less expensive cd player now as a opposed to waiting? Should my question be DAC <500, with a oppo 980? Will this give me a better sounding system then a former flagship CDP?ThoughtsYes. That's the only way I would go. If something happens to the CD player, you can always get another cheao one and run it through the DAC. Heck, you can use any old CD player that has a digital output when paired with a DAC. The DAC in the DAC will render the CD player's useless, so why spend a bunch of money on a CD player AND a DAC?All transport don't sound alike and digital cables make a big difference in sound Don't kid yourself about that a a good transport is just as important as the dac ED
Quote from: ecramer on 16 Apr 2009, 02:10 pmAll transport don't sound alike and digital cables make a big difference in sound Don't kid yourself about that a a good transport is just as important as the dac EDI never said they all sound alike. I said they WILL sound alike if you run them through a DAC (the same DAC). In that case, any transport will do since it is being run through the DAC. Please re-read what I posted.
The original Rega Planet is well under $300 and still holds its own. Ooooodles of reviews can be found on the net, I'm sure.
Quote from: Nuance on 16 Apr 2009, 07:25 pmQuote from: ecramer on 16 Apr 2009, 02:10 pmAll transport don't sound alike and digital cables make a big difference in sound Don't kid yourself about that a a good transport is just as important as the dac EDI never said they all sound alike. I said they WILL sound alike if you run them through a DAC (the same DAC). In that case, any transport will do since it is being run through the DAC. Please re-read what I posted. Ummm...all transports do not sound the same, but that is for another thread to discuss.George
Quote from: Nuance on 16 Apr 2009, 07:25 pmQuote from: ecramer on 16 Apr 2009, 02:10 pmAll transport don't sound alike and digital cables make a big difference in sound Don't kid yourself about that a a good transport is just as important as the dac EDI never said they all sound alike. I said they WILL sound alike if you run them through a DAC (the same DAC). In that case, any transport will do since it is being run through the DAC. Please re-read what I posted. One thing to keep in mind, besides jitter and the like, is the CDP or DVP's noisiness. There were several of us, who post on the AVA forum, that had varying experiences with a $39.99 Philips DVP. For me, the switched power supply, most likely, threw so much noise into my system that the entire sound was deteriorated by just having the Philips DVP powered up. Whether the problem was dirty AC or RFI or something else, the solution was easy. I took the Philips out of the system and obtained a quieter transport. In the future, I will always try to ascertain that the power supply, on any component that I purchase, is quiet. I can also offer an opinion on another CDP, the Jolida CD 100. The AVA DAC blows it out of the water. The Jolida made a nice transport, however.
As far as as your last question goes two many answers for that here's a couple of my suggestion this would be a couple of my choices Transporthttp://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1245038036&/ONIX-XCD-99dachttp://www.cryo-parts.com/music_hall_audio.htmlcdp standalonehttp://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1244912109&/Arcam-FMJ-33http://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1243046220&/Modwright-Sony-9000es-Signatur
Quote from: ecramer on 16 Apr 2009, 06:19 pmAs far as as your last question goes two many answers for that here's a couple of my suggestion this would be a couple of my choices Transporthttp://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1245038036&/ONIX-XCD-99dachttp://www.cryo-parts.com/music_hall_audio.htmlcdp standalonehttp://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1244912109&/Arcam-FMJ-33http://www.audiogon.com/cgi-bin/cls.pl?dgtlplay&1243046220&/Modwright-Sony-9000es-SignaturI was already checking out one of those arcam players, I really like their stuff personally, the couple times I heard it anyway. Cant decide which way to jump currently a little more researching for me. I do enjoy the suggestions and picking up a bit of knowledge is always good. I was going to go mostly HT with my setup but after hearing the ST with music I decided that was worth the expense of adding associated equipment. My only prob with that is there would be no way to play DVDA or SACD, neither of which I own but would like to try at some point.ThanksJared
That looks like a good deal on the Arcam, which I might want to pick up to use as a transport for my other DAC. I haven't heard the Music Hall DAC, but I didn't think the Music Hall CD25.2 CDP was anything to write home about, and at that price, I would look at a used AVA DAC. Jim demonstrates his products with AVA gear, and Jim stated that the AVA DAC "really shines." Although I am a loyal AVA customer and recommend AVA gear without any reservation, the bargain shopper should note that the PS Audio III DAC is on clearance for $700.00 brand new from the factory. Again, while I haven't heard the Music Hall DAC, I think that I would scrape up the additional $200.00 and get the PS Audio DAC, based upon others' reviews.
Quote from: Nuance on 16 Apr 2009, 07:25 pmQuote from: ecramer on 16 Apr 2009, 02:10 pmAll transport don't sound alike and digital cables make a big difference in sound Don't kid yourself about that a a good transport is just as important as the dac EDI never said they all sound alike. I said they WILL sound alike if you run them through a DAC (the same DAC). In that case, any transport will do since it is being run through the DAC. Please re-read what I posted. The problem is, I don't believe that's true, I can hear a difference between my opera consonsance cdp and my Onix cdp when they are both hooked up to my northstar dac but that just might be me. Ive heard it several times at raves ED
I heard the Music Hall dac at Shadowlights mini rave a couple of weeks ago most of us agreed it was better than Levis PS audio dac and cheaper I thought it sounded good for the money.
