0 Members and 2 Guests are viewing this topic. Read 14468 times.
The original Rega Planet is well under $300 and still holds its own. Ooooodles of reviews can be found on the net, I'm sure.
The nice thing about the Oppo is it handles all the advanced HT codecs internally or bitstreams them and does SACD via PCM or DSD..and on and on.I am sure there are other cd decks that are as good or even better built, but this one is in the sweet spot for a great all around player for stereo to HT and beyond.Alex
So, does Oppo BD-83 outperform all these BD's by Sony, Panasonic and so on <$500 in terms of a picture quality? Just curious.
I have decided to go ahead and get a dedicated cd player instead of using my PS3, I was wondering if anyone could throw out some suggestions on a nice neutral cd player <500, I plan on using just this until I get I can get a DAC. I'd like to be able to pop in DVDA and SACDs in just in case I get the urge but that isnt a deal breaker. I couldnt really decide where to post this but I figured on this section would be good,since you can tell me what you think works well with salks.Used is cool.Jared
http://www.decware.com/newsite/ZCD.htmDon
Should I be trying to get a DAC and less expensive cd player now as a opposed to waiting? Should my question be DAC <500, with a oppo 980? Will this give me a better sounding system then a former flagship CDP?Thoughts
Quote from: rahimlee54 on 16 Apr 2009, 11:10 amShould I be trying to get a DAC and less expensive cd player now as a opposed to waiting? Should my question be DAC <500, with a oppo 980? Will this give me a better sounding system then a former flagship CDP?ThoughtsYes. That's the only way I would go. If something happens to the CD player, you can always get another cheao one and run it through the DAC. Heck, you can use any old CD player that has a digital output when paired with a DAC. The DAC in the DAC will render the CD player's useless, so why spend a bunch of money on a CD player AND a DAC?
