Can somebody describe the pinout of the 6dn7 for me?
0 Members and 1 Guest are viewing this topic. Read 2125 times.
jrebman
I'm building a bottlehead s.e.x amp and would like to have a better idea of what is getting wired to what so I'm looking for a verbal description of the 6dn7 pinout as all I can find online are graphics.
Jim
BillB
Re: Can somebody describe the pinout of the 6dn7 for me?
« Reply #1 on: 14 Apr 2009, 02:21 pm »
Not sure what you are looking for but most data sheets have a verbal description under the pinout diagram, example:
http://tubedata.itchurch.org/sheets/093/6/6DN7.pdf
jrebman
« Reply #2 on: 14 Apr 2009, 02:33 pm »
Bill,
That PDF is a scanned image, not text, and being a blind person who is using a screen reader to use his computer, the scanned image does me no good.  Unfortunately, 99.9999% of all tube data sheets and schematics are graphics and scanned images.
-- Jim
ebag4
« Reply #3 on: 14 Apr 2009, 02:34 pm »
Jim,
Here you go:
Pin 1 is grid (section 2)
Pin 2 is plate (section 2)
Pin 3 is cathode (section 2)
Pin 4 is grid (section 1)
Pin 5 is plate (section 1)
Pin 6 is cathode (section 1)
Pin 7 is heater
Pin 8 is heater
Best,
Ed
edited for typos
jrebman
« Reply #4 on: 14 Apr 2009, 02:38 pm »
Thanks, Ed.  Any idea which section is the signal triode and which is the power triode?
What's your new speaker project?
You have to try the new genalex n709/el84s in your amp someday -- phenomenal!
-- Jim
mgalusha
« Reply #5 on: 14 Apr 2009, 02:41 pm »
Jim,
Section 1 is low power signal triode and section 2 is the high power with a plate dissipation of 10 Watts.
mike
jrebman
« Reply #6 on: 14 Apr 2009, 02:46 pm »
Thanks, Mike,  Don't know what I'd do without all you guys.
BTW, this is a very cool kit, extremely well documented and lots of room for tweaking and experimentation -- guess that's why the call it an "experimenter's kit". :-)
-- Jim
ebag4
« Reply #7 on: 14 Apr 2009, 02:46 pm »
Jim,
I'm not sharp enough to answer that question, but this is what the scanned doc. say about the two sections:
Section 1 is vertical oscillator service
Section 2 is vertical deflection amplifier
Hopefully that answers your question, if not I can pul additional info off the sheet.
I am currently looking into Danny's (GR Research) new OB.  It will be a bit before I can pick up the entire package but I an considering picking up everything but the bass units now.  97dB sensitivity should get me into SET territory which would be cool.
I guess your sex amps are for the horns?  I will be interested in your findings.
Best,
Ed
edit, I see Mike (someone who knows what they are talkng about) already answered your question.
jrebman
« Reply #8 on: 14 Apr 2009, 02:55 pm »
Ed,
I'll surely use it with the horns, but eventually the destination will be the bedroom where it will serve double duty as a headphone amp and drive that pair of zigmahornets I'm building.  Another couple afternoons in my buddy's shop and they should be ready to play -- except I have to wait for Bud to do the polka dot thing to the drivers.
Thanks again for your help,
Jim
BillB
« Reply #9 on: 14 Apr 2009, 04:30 pm »
OK, Gotcha Jim.
Sorry about that! Did not know that was the issue.
Enjoy the build!
