article on how to manage lossless music in itunes
0 Members and 1 Guest are viewing this topic. Read 2644 times.
jqp
Housteau
Re: article on how to manage lossless music in itunes
« Reply #1 on: 17 Apr 2009, 11:22 am »
I do not own a Mac right now, but will be considering a Mac Mini as a server soon.  As I know nothing about Macs and very little about I-Tunes, this guide is very helpful to me.  I knew about Apple lossless, but was not aware of how to use FLAC.  Can I-Tunes work with high resolution files in 24/96?
« Last Edit: 17 Apr 2009, 12:24 pm by Housteau »
Crimson
« Reply #2 on: 17 Apr 2009, 11:27 am »
I di not own a Mac right now, but will be considering a Mac Mini as a server soon.  As I know nothing about Macs and very little about I-Tunes, this guide is very helpful to me.  I knew about Apple lossless, but was not aware of how to use FLAC.  Can I-Tunes work with high resolution files in 24/96?
The audio engine in a mac, Core Audio, can support up to 32/192 files.
Housteau
« Reply #3 on: 17 Apr 2009, 12:26 pm »
What is Core Audio?  And does that mean I-Tunes will support 24/96, or will a different player be required?
Panelman
« Reply #4 on: 21 Apr 2009, 01:00 am »
iTunes supports 24/96, however you need to match the sample rate and bit rate of the song played in iTunes in Audio Midi to get 24/96 output
Art_Chicago
« Reply #5 on: 21 Apr 2009, 01:30 am »
Hey, I need an advice, too. apple.com states that a MacBook has an audio out, which is  a combined digital out/analog output (minijack) So, can a regular optical Toslink cable be used? I am thinking about using an external DAC for 24/96 conversion from www.HDtracks.com and itunes. Which software will work the best for it? Thank you!
Housteau
« Reply #6 on: 21 Apr 2009, 06:06 am »
Thank you.
Jason Brent
« Reply #7 on: 21 Apr 2009, 06:56 am »
not a regular toslink, but one that has a mini toslink on one end.  http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10229&cs_id=1022902&p_id=1558&seq=1&format=2
Art_Chicago
« Reply #8 on: 21 Apr 2009, 03:02 pm »
Thanks a lot, Jason!
