What center goes with ported Neo-2X's?
0 Members and 1 Guest are viewing this topic. Read 1802 times.
Stereodude
« on: 31 Mar 2009, 02:04 pm »
So, I have a pair of floorstanding ported Neo-2X's...
I was curious what the proper center channel to go with them is since I'm thinking of possibly adding a center channel.  Another floorstanding ported Neo-2X is not an option.  I would need something more like a horizontally mounted MTM or MT.
Is there a sealed N3 Neo design that would work, or is a sealed Neo-2X the correct match?
:scratch:
Nick77
Re: What center goes with ported Neo-2X's?
« Reply #1 on: 31 Mar 2009, 03:46 pm »
Danny did post pricing and box pdf for sealed N3 center channel. I am hoping to build one for my OB/7's.
      Re: New N3 kit (Neo series)!
« Reply #5 on: February 13, 2009, 08:42:45 pm » Quote
The X-MTM uses larger woofers and the box volume is a little more than what's needed for this design.
The boxes are pretty easy to build: http://www.gr-research.com/pdf/Neo3box.pdf
Here is the sealed box design that can be used as a center channel: http://www.gr-research.com/pdf/Neo3S.pdf
Danny Richie
« Reply #2 on: 31 Mar 2009, 04:23 pm »
Here is the thread on the new N3 kit: http://www.audiocircle.com/index.php?topic=64857.0
I single N2X will match nicely too if you have the vertical space for it.
fcraven
  • Don't mess with this baritone
« Reply #3 on: 31 Mar 2009, 05:51 pm »
Off Danny's advice I went with a sealed Neo-2X for my center, works great. And if you look at the photos in my thread, you will note that I retained the Vertical disposition..
Stereodude
« Reply #4 on: 31 Mar 2009, 10:34 pm »
What's the F3 for the sealed N3 Neo center?
Edit, nm I see it here is in the upper 80Hz.
Stereodude
« Reply #5 on: 1 Apr 2009, 12:10 am »
I wonder if it's possible to fold the TL in the floorstanding version of the N3 Neo into a deeper, but not ~42" wide MTM center channel?  :scratch:
dvenardos
« Reply #6 on: 1 Apr 2009, 01:00 am »
Just make a bass box stand that consists of a SW-12-04.  :icon_twisted:
Stereodude
« Reply #7 on: 1 Apr 2009, 01:08 am »
Uh... that's not what I'm after.  I'm already going to have a sub using 2 SW-12-08's in the system.  I just want a similar low frequency response across all 3 front speakers if I end up building a center channel.
Danny Richie
« Reply #8 on: 1 Apr 2009, 03:03 am »
What you are proposing would be pretty tricky. Even with the sealed box it will blend to the subs much better than you'd think.
