adding a power switch
0 Members and 1 Guest are viewing this topic. Read 971 times.
santacore
« on: 28 Mar 2009, 10:29 pm »
Hopefully one of you guys can help me out. I recently picked up a great Decware preamp. By design, there is no power switch on the unit. Because it's a tube pre and I have small kids I don't want to leave it on all the time. I'm looking for a suggestion on how to add a power switch to the unit without modifying the chassis. The only easy idea I can think of is adding a power strip or conditioner. I'd prefer not to do that due to the possible effects on sound and space limitations. Any other suggestions would be appreciated. Thanks.
markC
Re: adding a power switch
« Reply #1 on: 28 Mar 2009, 10:55 pm »
Assuming it has an iec inlet, you could use a small box with a male connector on one end and a female on the other. Install a switch and wiring in the box and plug it in. Not the best scenario, but given that you don't want to alter the chassis, it's an idea.
