Ultra vs. T8: Why is one tube and the other hybrid...
0 Members and 1 Guest are viewing this topic. Read 1449 times.
orthobiz
...when they both have two tubes (four each if you count phono)?
A really simple answer, please, as I am not an electronics wiz.
Paul
Tone Depth
  • Music Lover
    • SRLPE Wheel Works
Re: Ultra vs. T8: Why is one tube and the other hybrid...
« Reply #1 on: 22 Mar 2009, 03:09 am »
Paul
I'll take a try at this answer, although I'm sure there are others who could do a much better job:
The Transcendence 8 (T8) does the preamplification work with tube circuits.
The Ultra uses both tubes and transistors to each do part of the preamplification work, and is therefore a hybrid preamplifier.
charmerci
« Reply #2 on: 22 Mar 2009, 03:39 pm »
I'm sure someone is going to come on right after me and give a more detailed and better explanation...  :)
I'm not even sure if this is the entire explanation of why it's a hybrid.
Frank's hybrid uses the tubes only for the electrical voltage regulation, i.e. raising it.
