iPhone apps for Bryston
0 Members and 1 Guest are viewing this topic. Read 2118 times.
Levi
« on: 18 Mar 2009, 01:51 pm »
Hi James,
I would like to use my iPhone to control my Bryston processor.  it is not complicated to create apps for iPhone/iTouch.  Is this something Bryston is considering of doing?
Thanks.
Levi
  • The Demo is Everything!
    • http://www.bryston.com
Re: iPhone apps for Bryston
« Reply #1 on: 18 Mar 2009, 02:26 pm »
Hi James,
Thanks.
Levi
Hi Levi,
We have not looked at it to this point but if you come up with something please let me know.
james
Levi
« Reply #2 on: 18 Mar 2009, 03:07 pm »
Thanks James.
This is what is out there.  Airremote a separate box that iPhone or iPod communicates to via wireless lan.
http://www.airremote.com/index.php?page=0
Sonos also have one to control their system via wireless lan.
http://www.sonos.com/whattobuy/controllers/iphone/default.aspx
Finally, SAVANT.  It is like Airrmote with a separate controller box.
http://www.savantav.com/home.php
gaderson
« Reply #3 on: 20 Mar 2009, 08:58 pm »
The easiest way is to have a web interface that you can access by the iPhone, other than the examples above. I know that the Denon AVP-A1HDCI has such an interface, it's been referenced in the AVSfourm threads (or page 68 in the manual).
Though I would find it better to use this interface to save various setups so we can do backups of settings when doing firmware updates and other configurations.
