5Y3WGTB rectifier,
0 Members and 1 Guest are viewing this topic. Read 3915 times.
denverartist
5Y3WGTB rectifier,
« on: 16 Mar 2009, 11:31 pm »
I have been experimenting with rectifiers in my Cornet 2. After using very good GE and Amperex 5AR4 which gave ~362V B+, I found a number of NOS 5Y3WGTB, a 5Y3-type rectifier that is indirectly heated, for slow warm-up like the 5AR4. Well, I wanted to buy 2 but had to get all 8. They sound very good, and test well. But I can't undertand how the lower voltage, 338V at B+, can still sound "better".  There was some discussion of rectifiers in another thread.
Either way, I have 6 extras if anyone wants one or 2. I just want to get back what I have in them, $15 apiece. Sorry, If I am breaking a posting rule by bringing this up, I will delete the post.  :nono: Contact me off list. They are CBS Hytron (brown base, black plates) from the late 50's.  (EDIT: all tubes are spoken for)
Any thoughts on ths rectifier?
Pete
« Last Edit: 5 May 2009, 06:53 pm by denverartist »
ldandha
Re: 5Y3WGTB rectifier
« Reply #1 on: 17 Mar 2009, 12:53 am »
Hey Pete, I just sent you a PM regarding the CBS tubes.
galyons
« Reply #2 on: 17 Mar 2009, 01:52 am »
Hi Pete,
They look very much like the GE 5 Star 6087/5Y3WGTB rectifier that I am using. Mine is dated 35th week of 1959. Plate structure and rectangular getter appear identical, at least from what I can tell in the pictures! I have a 25-30 second warm-up from red to green.
I need to retest my B+ as it was a bit low (-10% about 332VDC) when I first powered the C2 up and measured the test points.  But perhaps that is a characteristic of the 5Y3WGTB?
I like the sound of the GE 6087/5Y3WGTB , but haven't compared it to other rectifiers in the circuit.
Geary
galyons
« Reply #3 on: 17 Mar 2009, 01:59 am »
Pete just a thought, is there an EIA 3 number manufacturer's code on the tube? CBS Hytron is 210, GE 188.
Geary
denverartist
« Reply #4 on: 17 Mar 2009, 03:05 am »
Yikes! I had no idea the tubes would all vanish in an hour. My apologies to those I had to turn down.
Actually there is no manuf code. One has a date code of 1959, others a code of 'PG'.  They do look like some 5-star GE's I once had.  5Y3 always has more voltage drop than 5AR4. Not sure how the specified 5Y3 (for C2) ever made the 365V B+ printed on the circuit board.
Pete
« Last Edit: 17 Mar 2009, 05:43 am by denverartist »
denverartist
C2
« Reply #5 on: 2 May 2009, 04:12 pm »
nt
« Last Edit: 5 May 2009, 06:54 pm by denverartist »
amandarae
« Reply #6 on: 7 May 2009, 06:30 am »
Pete
Hi Pete,
Try a Sovtek and it will.  The Sovtek 5Y3GT is in my opinion, a rebranded 5AR4.
regards,
Abe
