0 Members and 1 Guest are viewing this topic. Read 8747 times.
Speaking of AC power, each of the thirty AC wall outlets were wired to their own 20-amp breakers via its own "home run," which is a direct wire run from an outlet to a breaker. The exception to this is that each of the mono amplifiers runs at 240v and are wired to their own dedicated 30-amp breakers.Collectively, over 2000 feet of rather expensive hospital-grade BX cable was consumed during the wiring of this studio. There are a total of 440 amps coming into the building. The circuits feeding the audio components are deliberately separated and placed in their own 220-amp Siemens commercial breaker box, complete with bolt-in, copper-clad circuit breakers. The second 220-amp panel feeds the security system, lights and mechanicals, including two tons of AC!
Do you really need 400+ amps just for the sound equipment? I run my entire system (granted, not near the quality of this) off of a single 20 amp circuit. I could see a few more circuits, but the amount of wiring he has in there is overkill, especially when the amps are on their own 30 amp 2 phase dedicated circuits.
Jeff,how did you come across those speakers ?? they look great.are they a hard drive ??
Looks a bit like Mike's room..
