0 Members and 1 Guest are viewing this topic. Read 5952 times.
bigbwb,Cool good reply..and I understand its a convenience thing...I did read that even FLAC is compressed, even though its a lossless format. Anything I hear that uses compression I am wary of. but sounds like many to play FLACS etc and like it very much...especially for the things you mentioned.Thanks for the insight!! I feel enlightend !! Alex
My advice? With a slight exception to the latest generation of Macbook's, most Laptops are highly compromised with regard to sound quality. That said, there are two solid ways to go about this.The first way involves buying the best DAC and AMP that you can afford for now. You won't need a pre-amp right away as you can use the laptop to control the volume. Add a pre-amp once you're in a comfortable financial position to do so.The second way involves buying the best DAC and interegrated amp/stereo receiver that you can afford. Depending on the budget, this route is simpler and could yield some excellent results. At the end of the day, this will boil down to a few things. First, how much money can you allocate towards new electronics? Second, do you want to buy new or used?
What's your budget?
