0 Members and 1 Guest are viewing this topic. Read 25821 times.
I use a IBM deskstar for a speech recognition computer and it was rated the "queitest" at the time.
The smaller you get the more concentrated the heat becomes, and the more you need fans to cool components. Even with the heatpipe there, I'd worry about long term reliability of things like hard drives and CPUs.
I use Musicmatch as my audiojuke box
You tried Foobar2K? I highly recommend that over anything I have tried. .
Thanks Hantra, I'll check it out. What do you use to rip CD's? I am using Media Jukebox as it can be customized to rip at very high quality in addition to ripping at 320 kbs.
Which version do you recommend? Thanks. DU
