0 Members and 1 Guest are viewing this topic. Read 65163 times.
It's not SET but it is 50 watts of 300bhttp://canaryaudio.com/339.htm
Quote from: iGrant on 7 Feb 2009, 02:51 pmNow if you can build a 50 watt 300B SET, you will rule the audio world Cheers,IanIt's not SET but it is 50 watts of 300bhttp://canaryaudio.com/339.htm
You run a tube amp company and are asking if 300Bs are 'worth it' compared to KT88s - but not considering sonics?? What does that mean?Any power triode, most especially a direct-heated triode, has a sound rather different than a pentode. You should listen and decide if they're worth it. Many of us find them quite superior, and the paper linearity of DHTs (and the subsequently simpler circuits) makes that sensible.By the way, $200/pr is close to the low end of the scale. IMO the best 300Bs are EML and KR, both running significantly more than that but not nearly as much as NOS WEs.
Hi Pete-Yeah, there are several attractive 300b's on the market. Unfortunately their prices are stoked way up there. If the price is justified in longevity and sonics vs., say the $180.00/pair Electro Harmonix tubes, then it's worth it. From what people say, the 300B has ALLOT of potential and I would like to see the prices fall on them so they could become mainstreamed. I don't know whether the prices are high due to artificial reasons or because not enough of them are purchased. I can understand why the specialty 300B's are expensive- but hopefully a large manufacturer will start to push more of them on the market. EH may be doing just that...I don't know.
I currently own WE 300B's, KR 300B's, RCA 50's, Sylvania VT-10A's as well as Philco 10's.
i would never be interested in any amp that uses 300b tubes. like rim, i think they are too expensive. i think 6c33c tubes make exceptional set sound - all 300b adwantages w/o the penalties. sonically, anyways - the 6c33c tubes put out a tone of heat, and draw a lot of power...doug s.
Quote from: Triode Pete on 8 Feb 2009, 02:28 pmI currently own WE 300B's, KR 300B's, RCA 50's, Sylvania VT-10A's as well as Philco 10's. Hi Pete. Just curious ... which triode is your favorite among all those you've owned or tried? Keith
