0 Members and 1 Guest are viewing this topic. Read 65157 times.
Quote from: Triode Pete on 10 Feb 2009, 09:02 pmI have a 71A Stereo Single Triode Linestage Preamplifier with separate dual regulated tube power supplies. Extremely sweet sounding with just enough gain. Toughest part is getting non-microphonic 71A tubes. Currently using a pair of RCA Radiotron UX-171A globe triodes. The ST-shape ones were too microphonic.The one pair of globes I have is more microphonic than my ST bottles, but they all vary quite a bit and all are more microphonic than a 300b for sure.Is the preamp transformer or RC coupled at the output?I use the tube in both a headphone amp (single stage xfrmr output) and a power amp (ECC99 xfmr coupled to the 71). The amp will run out of gas much sooner than 300b's on the same speaker, but I never actually get there in normal listening - I would guess my average listening level is in the mid 80's which translates to 50, maybe 100, milliwatts on my 101dB speakers. This is also a reason why a low power operating point worked so well with the 300b in my set up.BTW, I agree with your profile comments on power conditioning - it's never improved a system I've had and made things worse more often than not.
O.K. boys, read up. Here's the shinny on the 300B.
- low AC plate resistance on the output tubes.
- Fixed bias for the output tube- 300B's are direct filament and have to becathode biased.
- Most 300B tube amplifiers use tube rectifiers- 5U4 etc. No tube rectifiercan handle more that 185Ma's of current ( less that 1/4 of an amp!)
-So to sum up 300B amplifiers have very poor slew rates, rise time- speed,have insufficient power supply capacitance, average at best frequencyresponse, poor bass due to the cathode biasing and also electrolytic capsare used in the cathode circuit as a AC ground return and are directly inthe signal path. Also most 300B designs do not even have proper drive stagesfor the output and further contribute to average at best transient response.
-A good amplifier will have lots of power supply capacitance and lowimpedance, well designed input stages with driver stages to proper drive theoutputs, fixed bias for fast transients and good output iron. Sadly the 300Band designs using this tube are lacking most of the above.
Quote from: Rocket_Ronny on 12 Feb 2009, 06:45 pmJoshk:Now I am going from memory, but seems that what was said is that the 300B rise time was slow, as in the tube itself, and that it was a poor tube choice to design an amp around. Everyone has their opinions I guess. I don't think that is right. But I am going to defer since I can't refute that 100% technically, I'll have to come back when I've verified my facts. Maybe some engineer can help out.
