Community
Non-audio hobbies and interests
The IT Crowd
GentleBender
USB external HD case failure
0 Members and 1 Guest are viewing this topic. Read 1513 times.
mcgsxr
Mark in Burlington, Canada
1 Feb 2009, 08:24 pm »
Never seen that before.
I have a 200G that I use as my outboard backup.
Would not boot today, would not turn on at all.
Pulled the drive, installed in my desktop, and it is fine.
Guess I get to shop for enclosures now...
jqp
Volunteer
Each CD lovingly placed in the nOrh CD-1
Re: USB external HD case failure
1 Feb 2009, 09:21 pm »
You are lucky you didn't loose data though - in the past I have had more than one enclosure cause problems - there were some chipset problems that involved drive capacity limits. Also some enclosures may be cheaply made with inferior cables, etc.
mcgsxr
Reply #2 on:
1 Feb 2009, 10:17 pm »
I do consider myself lucky indeed.
I suppose it could be the power supply (external to the external HD case), I have no way to check it.
Once I buy a new case, I will be able to check it.
Here's to backing up your data...!
Crimson
Volunteer
(220, 20, 60)
Reply #3 on:
1 Feb 2009, 11:04 pm »
Quote from: mcgsxr on 1 Feb 2009, 10:17 pm
And backing up your backups. The more the merrier!
Community
The IT Crowd
GentleBender
