So what are you OB guys doing w/ the plate amp?
0 Members and 1 Guest are viewing this topic. Read 5499 times.
drphoto
« on: 27 Jan 2009, 07:03 pm »
Well the amp came today. I guess I expected it to be fully enclosed, but no, the back is wide open. No problem is you build it into a box sub, but what about the OB setups? Just build a box of some sort for the amp itself seems obvious, but I'm curious to see how some of you have implemented your solutions. Pics please if you have them.
thanks
mcgsxr
Re: So what are you OB guys doing w/ the plate amp?
« Reply #1 on: 27 Jan 2009, 10:38 pm »
I don't have any pics at the moment, but I simply built a small box out of mdf for the plate amp.
It sits on the rack, with the other gear, and longer speaker cables run out to the subs.
If you build a U baffle, the amp could be put into one of the sides of the container.
dweekie
« Reply #2 on: 28 Jan 2009, 12:26 am »
Hawthorne Audio builds enclosures for the Rhythmic plate amps.  It looks nice to me, especially if you can match the enclosure (or baffle in the case of OB).
drphoto
« Reply #3 on: 28 Jan 2009, 05:10 am »
Hey that looks good. I sent an email to Hawthorne. Thanks Dweekie.
stevenkelby
  • Adelaide, South Australia
« Reply #4 on: 28 Jan 2009, 12:10 pm »
Can you guys tell me how much hum there is from the plate amp itself, not through it's outputs, which I'm sure are close enough to silent, but how much hum you hear from the amps powered up with no source, and your ear next to the plate amp in a silent room ion the middle of the night?
Every plate amp I've seen has some hum, even great ones, it's no problem at all of course and I'm sure these are no different with humming a little, just curious how much? Subjective I know, but can you give me an idea? :)
Danny Richie
« Reply #5 on: 28 Jan 2009, 04:33 pm »
That box looks good and is very similar to what I will be doing with this new open baffle kit that I am about to release.
Looking at that pic though, I only see one set of binding posts. For the servo sub amp there needs to be 4 of them.
With this kit, I will be supplying a 4 pole SpeakOn connector. So you can come straight out of the box with the wiring using a nice looking braid or something and go right into the SpeakOn.
I have not noticed any amp hum from the amp itself.
stevenkelby
« Reply #6 on: 29 Jan 2009, 05:55 am »
Thanks Danny. They must be pretty quiet then! It's it's only in my insulated room late at night when all is silent that I notice it. Every other component in my system is battery powered/silent so it's good to hear that this plate amp is quiet too. :)
laserman
  • Ambiguous-Optimist
« Reply #7 on: 29 Jan 2009, 03:35 pm »
+1 on plate amp being quiet.
L
drphoto
« Reply #8 on: 29 Jan 2009, 06:15 pm »
Danny, any time frame on your enclosure? Will you be selling it as a separate item? I wouldn't need one made out of fancy stained hardwood. I'm going to make my baffles out of MDF, seal them, and finish w/ black truck bed liner. I could do the same w/ the amp box.
Yeah, I wondered about the single set of terminals too. However, are terminals needed? Couldn't one just solder push tabs to the speaker wire and use the existing connectors on the pigtails?
BTW: Hawthorne told me someone else from this forum contacted them, but they haven't been able to reply to your email. Dunno who it is. Maybe your inbox is full.
Danny Richie
« Reply #9 on: 29 Jan 2009, 07:38 pm »
Enclosures for the sub amp can be ordered from Eric Stegall (Eargasm).
If you are going to make your own baffles then you should be able to make a box for the amp to fit into.
There is half of a dozen ways that one can make the amp removable from the speaker.
I haven't contacted them but one of their customers recently sent me one of their drivers to have a look at. That might be the connection that they are thinking about. I get tons of e-mails every day and my e-mail server doesn't ever get full.
jk@home
« Reply #10 on: 30 Jan 2009, 02:12 am »
 I built a box out of a electrical enclosure, with added aluminum angle and flat bar. Turned out nice, but was a PITA to build. Go for the wooden one. :D
Here's a link on how to make one using MDF:
http://www.io.com/~patman/ampbox.html
drphoto
« Reply #11 on: 30 Jan 2009, 03:05 am »
Well Danny, you're right, if I can do the baffles, I can do the box. But you've got to factor in 3 jobs, school and inherent laziness.  So I was looking for an EZ solution.   :wink:
 JK.....that box is sweet! Nice job.
dweekie
« Reply #12 on: 30 Jan 2009, 04:25 am »
Huh, I am curious what you think.  Pretty much all my speakers now (exept for some junk ones I use on testing unknown equipment) have some of your work or Hawthorne's.
KCI-JohnP
« Reply #13 on: 2 Feb 2009, 10:53 pm »
Man I like that, you  did a fine job on that baby!  :thumb:
