Hi there, I was wondering if any has an alignment tool that they think could work with a VPI jmw 10 arm, which has the following characteristics . . .I'd love to borrow it if possible.
Those are horrible numbers. They make my Baewald calculator go off the chart. First null point is probably on the spindle, the second null point is 145mm and the distortion is 1.114%. I'd recheck your arm specifications. Something wrong.Actually if you used 265mm (250 spindle to arm), 15mm overhang, and 20.5 degrees offset, the calculator looks great. Distortion is down to .414%Wayner
http://www.vacuumstate.com/index.tpl?rubrik=4&lang=2&a=v%25C9%25D5%2508%25A4%2508%25AE%258C&b=733795.2837762678dave
The only real problem is the offset angle. 22 degrees is bad, 20.5 degrees is good.20.5 degrees puts null points at 63.3mm and 121.4mmWayner
I'm a little confused with the Guru instructions. I don't think you are actually moving the cartridge back in its mounting to the head. That would change the overhang and effective length. I think you're just using that slight offset to then align the cartridge sides. I too plan on trying this this weekend and see if I notice much of a difference.My cartridge is a HOMC (20X-H) and is far less finicky than most LOMC's, so I'm not sure that I'll hear much of a difference. But then, I still have a hard time believing I hear a difference between different kind of stings used to spin the platter, but I do.We'll see.Thanks,Bob
Tried the Guru method over the weekend and it sure does sound nice. I can't say that there was any significant difference between the regular setup and the Guru method for alignment, but it certainly didn't cause a problem.The nicest thing about the Guru link and paper was the description of setting anti-skate. I've never seen anyone describe what to listen for and how to go about figuring out what is proper. This is the first time I've seen ANY method at all for this setting. Well, it did work for me as described. I was able to identify a range where the sounds they describe came more into focus dynamically, so I guess I can say that it works as described.In any case, the adjustments over the weekend playing with the Guru methods helped me to readjust my cartridge alignment, which I needed to check anyway. So it was a good use of a 1/2 hour anyway. It's all good.Enjoy,Bob
