Actually, it's more of twisting the body to align with the lines on the Guru protractor. It's not moving the cartridge backwards (thereby affecting the overhang and effective length, which you don't want to do). It's just a realignment of the cartridge squarely to the groove.Bob
these, which are not on any exact radial line fromthe center, are the alignment points we suggest for the diamond torest and the cartridge then be twisted and/or moved back and forwardso it aligns with the parallels at both red arrowed intersection points.
Bob, I understand what you're saying regarding aligning the cantaliver, but I think the whole thing is to also move the cartridge (stylus) back 1.27mm as well, effectively reducing the recommended effective length by 1.27mm.In anycase, I am glad it works for you wonderfully.T
I agree that there is some plus or minus stuff here, not any magic window. However, good spots make for better record wear, IMHO.Wayner
