0 Members and 1 Guest are viewing this topic. Read 49301 times.
I am still wary of the plastic issue at the lower temperature. It's still pretty hot and I just have it in my head that the combination of heat and plastic cannot be the healthiest mix, especially where ingestion is involved. A great brewing method, though, that Aeropress.Best,KT
I purchased an Aeropress very shortly after they came to market and must say, it does make very nice coffee. I highly recommend it.I haven't used it for a little over a year, though, for this reason: I get really concerned when boiling hot water hits the plastic and heats it up for several minutes. Specifically, I'm concerned about chemical leaching, particularly BPA and pthalates ( http://en.wikipedia.org/wiki/Phthalate ).Though there seems to be no solid consensus on whether BPA actually is as bad as is claimed, there seems to be a lot of studies out there that do raise red flags for me. And that's in vessels used at room temps. Raise that to boiling temp and I'd think any sort of chemical leaching would be worse.I was hoping, after Nalgene, Camelbak, and others changed their plastic formulation to BPA-free, that Aerobie would do the same in the Aeropress. As far as I know, that hasn't happened.So right now I use a small Bodum glass french press. The coffee comes out different between the two. I prefer the Aeropress; it's like a cross between french press and espresso. I, myself, prefer my coffee on the strong, robust, flavorful side.I may pull out the Aeropress again and use it very sparingly; I really like the way it makes coffee. Too bad about he plastic thing, though. I just get a really bad feeling in my gut about mixing boiling water in plastic, letting it heat up and steep for several minutes, and then then drinking that water, day after day after day.... (incidentally, I ditched my plastic Procter-Silex plug-in water kettle and replaced it with the Capresso glass model for the same reason, and try to avoid heating food in tupperware containters in the microwave, where there tend to be numerous overheated hot spots. No, I'm not an alarmist, just taking what I feel to be reasonable, easy-to-implement-and-manage precautions just in case.)Anyhow, just my observations and concerns.With any of these methods, a good grinder is critical. I use a discontinued Kitchenaid Professional model that was positively reviewed on Coffeegeek.comBest,KT
Quote from: KT on 18 Oct 2009, 03:37 pmI purchased an Aeropress very shortly after they came to market and must say, it does make very nice coffee. I highly recommend it.I haven't used it for a little over a year, though, for this reason: I get really concerned when boiling hot water hits the plastic and heats it up for several minutes. Specifically, I'm concerned about chemical leaching, particularly BPA and pthalates ( http://en.wikipedia.org/wiki/Phthalate ).Though there seems to be no solid consensus on whether BPA actually is as bad as is claimed, there seems to be a lot of studies out there that do raise red flags for me. And that's in vessels used at room temps. Raise that to boiling temp and I'd think any sort of chemical leaching would be worse.I was hoping, after Nalgene, Camelbak, and others changed their plastic formulation to BPA-free, that Aerobie would do the same in the Aeropress. As far as I know, that hasn't happened.So right now I use a small Bodum glass french press. The coffee comes out different between the two. I prefer the Aeropress; it's like a cross between french press and espresso. I, myself, prefer my coffee on the strong, robust, flavorful side.I may pull out the Aeropress again and use it very sparingly; I really like the way it makes coffee. Too bad about he plastic thing, though. I just get a really bad feeling in my gut about mixing boiling water in plastic, letting it heat up and steep for several minutes, and then then drinking that water, day after day after day.... (incidentally, I ditched my plastic Procter-Silex plug-in water kettle and replaced it with the Capresso glass model for the same reason, and try to avoid heating food in tupperware containters in the microwave, where there tend to be numerous overheated hot spots. No, I'm not an alarmist, just taking what I feel to be reasonable, easy-to-implement-and-manage precautions just in case.)Anyhow, just my observations and concerns.With any of these methods, a good grinder is critical. I use a discontinued Kitchenaid Professional model that was positively reviewed on Coffeegeek.comBest,KTI think that a potential problem with plastics is phthalates:http://www.proteinpower.com/drmike/uncategorized/phthalates-in-obesity-and-insulin-resistance/I thought these were only in soft plastics? Also, the study reviewed in the link does not prove causation; it is interesting, however.
After reading this report, I think I'll be switching from plastic containers to glass when it comes to microwaving food from now on.
Quote from: satfrat on 4 Dec 2009, 09:27 pmAfter reading this report, I think I'll be switching from plastic containers to glass when it comes to microwaving food from now on. That's a good plan Robin. I switched long ago, after sometimes being able to smell a plastic odor emanating from microwaved plastic. If you can smell it, then chemicals are being released. I kind of wish Aerobie would would offer a glass Aeropress model for those so inclined. I would be willing to pay the extra cost as well as the replacement parts cost when a component breaks (and if it's glass, it probably eventually will). But I guess if they did that, they would be inadvertantly implying that their plastic model might be unsafe. Of course there are different strengths and thicknesses of glass. I have dropped some heavy duty Pyrex pieces with no breakage, while I have also somehow broken the glass carafe of the Bodum French Press just by looking at it sideways. Steve
I too would be happy to switch to a glass press so long is it retained the filters. I know folks who like grinds in their coffee,,, I'm not one of them. A also know what you mean
You can smell some things at far lower concentrations than could possibly be harmful. In some cases it only takes a few molecules to be able to smell something.
My coffee mugs are Bodum glass (the thick single-wall ones) and ceramic with glaze that isn't lead-based. (From Phaltzgraff, Homer Laughlin, and a local potter that I've talked to about what glazes he uses.)
There are some oils contained in coffee that really aren't that good for you. Using paper filters removes most of those oils. (I was just reading about this in a book by Joe Schwarcz - "An Apple A Day")Some people don't like the taste of coffee that's been filtered with paper though. So, as always, YMMV.
Quote from: turkey on 5 Dec 2009, 03:04 pmYou can smell some things at far lower concentrations than could possibly be harmful. In some cases it only takes a few molecules to be able to smell something.Yes, but neither you or the scientists know exactly what those thresholds are. The worst offenders seem to be the throwaway ones that the food is packaged in.
I was just pointing out that the "smell" test may not be terribly reliable.
Quote from: turkey on 5 Dec 2009, 04:53 pmI was just pointing out that the "smell" test may not be terribly reliable. I understand what you're saying. But I get no smell from glass, and I'm reasonably confident it is as chemically inert as any material can be, at least when used under 1000 degrees Farenheit. Steve
You get no smell from lead crystalware either.http://www.hc-sc.gc.ca/hl-vs/iyh-vsv/prod/crystal-cristal-eng.php
How to brew a good cup of coffee. Very thorough. http://vimeo.com/8628771
Anybody else trying the Clever Coffee Dripper? I got tired of replacing my press pot glass, and thought I'd give this a shot.
I can still taste the filter even though I pre-rinse.
