BP25 Code Needed for BCD-1 Remote.
0 Members and 1 Guest are viewing this topic. Read 1678 times.
ChrisBo
« on: 17 Jan 2009, 07:26 pm »
Hello Everyone, I finally got my BCD-1 last night and I am quickly working my way through my fav CD's.
Does some one out there have the code for the BP 25?  I do not have it listed in my owners manual.
Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP25 Code Needed for BCD-1 Remote.
« Reply #1 on: 17 Jan 2009, 07:31 pm »
Thanks.
Hi Chris,
Should be the same as the BP26.
Programming the remote control:
The infra-red remote control supplied with the BCD-1 can also be used to control the volume and mute functions several other Bryston products. To program the BCD-1 remote control to operate other Bryston models follow these steps:
1st) Press and hold the CODE button on the BCD-1 remote until the red LED begins to flash (usually takes about 5 seconds).
2nd) Enter a three digit code as follows:
       721 : BP26 preamp
The red LED will flash twice after a code has been entered successfully.
james
ChrisBo
« Reply #2 on: 19 Jan 2009, 12:03 am »
Thanks for the quick reply ... I tried the code a few times although, it doesn't seem to work ... is there a way to reset the remote and try it again?
« Reply #3 on: 19 Jan 2009, 12:15 am »
Hi Chris - your BP25 probably has an older codes - contact Mike Pickett at Bryston and he will give you the instructions for changing the code.
[email protected]
james
