0 Members and 1 Guest are viewing this topic. Read 8253 times.
I would think that all MDF is medium density, as it stands for Medium Density Fibreboard... http://en.wikipedia.org/wiki/Medium-density_fiberboardAre you looking for HDF? http://en.wikipedia.org/wiki/Hardboard
I would use double refined MDF which is very strong for MDF.
I am still undecided as you have stated to use a "double refined MDF" and the MDF core is listed as "Medium Density".
I am with Planet10 on this one, having built speakers with both mdf and baltic birch ply, the ply is well worth the extra expense, and effort. My current OB speakers are still in raw mdf form, but my intention all the long (alright it has been almost 4 years...) has been to make the final baffles with baltic.
Hi:I recently purchased some SS drivers from Rick and also from one of his customers out in California. I am planning on making the "Texas Tower" that Fred down in Texas made. I was talking with a woodworker/cabinet guy who has done work for me at my home in the past about my project and I asked about possible sources for good MDF (not all MDF is the same...). I also mentioned possible sources for veneer. His response was why do that when you can order MDF Core Veneer? He turned me on to a product that looks very good! See the below link...http://www.cfpwood.com/products/default.aspxYou can either get regular plywood veneer or MDF core veneer. If you scroll down on the right side you will see the available veneers(you can also special order a species not listed). The price for a 4x8 sheet of 1" MDF Core with a Walnut veneer is $98. Has anyone gone this route for DYI'ing speakers? One of the questions I have is that on the above website it mentions that the MDF Core is "Medium Density". However, it is also very low in it's Formaldyhyde content.Pro's or Cons over the MDF and then applying veneer method??Thanks,rklein
The quality of the core is usually good with the pre-veneered MDF sheets; however, the veneer can really vary and you cannot make matched cabinets.
Thanks for all of the replies. I appreciate it. QuoteThe quality of the core is usually good with the pre-veneered MDF sheets; however, the veneer can really vary and you cannot make matched cabinets.I agree with Rick. However, a local company(Cleveland Plywood) stocks the MDF Core with most of the standard veneers, so I do have the ability to go and select a couple of sheets to try and match them as closely as possible.Thanks,rklein
