0 Members and 1 Guest are viewing this topic. Read 13080 times.
Very interesting. Will this be a 2.5-way design? Can't wait .
When I saw the title of this thread, I immediately thought of Charles Whitman. Remember him?
Rick,I don't think you will choose one for us as it depends on different conditions but...Would you prefer the Scan3 or V3DP sound to the 2.5-way TRT? To me, it seems the integration obtained with the 2.5-way design surpasses that of a well designed 3-way at the loss of bass extension.
Quote from: tf121682 on 25 Aug 2008, 04:57 pmRick,I don't think you will choose one for us as it depends on different conditions but...Would you prefer the Scan3 or V3DP sound to the 2.5-way TRT? To me, it seems the integration obtained with the 2.5-way design surpasses that of a well designed 3-way at the loss of bass extension. A 2.5-way is normally a result of wanting a floorstander with a narrow cabinet and increased output capability versus a standard single woofer 2-way. If there's some flexibility in cabinet width (or shape with a trapezoid allowing a larger woofer at the bottom like our Galena) then a 3-way is a better option.
Quote from: Rick Craig on 25 Aug 2008, 05:57 pmQuote from: tf121682 on 25 Aug 2008, 04:57 pmRick,I don't think you will choose one for us as it depends on different conditions but...Would you prefer the Scan3 or V3DP sound to the 2.5-way TRT? To me, it seems the integration obtained with the 2.5-way design surpasses that of a well designed 3-way at the loss of bass extension. A 2.5-way is normally a result of wanting a floorstander with a narrow cabinet and increased output capability versus a standard single woofer 2-way. If there's some flexibility in cabinet width (or shape with a trapezoid allowing a larger woofer at the bottom like our Galena) then a 3-way is a better option.Thanks for the explanation. I like the idea of doing a WWMT tower with the same drivers as the large CC you built to mate to the Galena. Having those for R and L, your large CC anchoring the middle and some SSRs as surrounds would be fantastic. I already have an IB sub so I need speakers that can match the speed, output and low distortion. How much would a 7 channel kit like that run? I need some time to work on the wife , she cut me off because I got a new watch, but usually she comes around. It probably won't be 'til next spring, but hopefully by then the frost will have melted (pun intended!). This is a setup that others might be interested in, too.EDIT: Oops ... I quoted the wrong post. I meant to quote Rick's response to my question about 2.5-way speakers vs. 3-way speakers.
I hope Fred and all of the Houston area AC guys are doing well after the storm. Having been without power for ten days after Hugo I certainly can understand what you are encountering. Hang in there!
Rick, What would be the depth of the two different versions, and how much would a kit cost?thanks
Quote from: Rick Craig on 18 Sep 2008, 10:33 pmI hope Fred and all of the Houston area AC guys are doing well after the storm. Having been without power for ten days after Hugo I certainly can understand what you are encountering. Hang in there!Thanks for the kind thoughts. I must be leading a charmed life. Left Houston last Wednesday to get out of Ike's way, spent a few days in the Austin condo, then returned Sunday morning to find no damage at all except for a couple of blown out fence boards. By Thursday we still had no power, it was beginning to get hot, and I was beginning to feel audio withdrawal symptoms, so I returned to Austin for a few more days. Returned home again last nite and found I have power and all the associated amenities we take for granted, like TV, electric lights, music, and power tools for building even more speakers. I'll be doing the driver cutouts for Trey's Seas/Morel/Fountek three-ways this week.
