Are All Belts Created Equal
0 Members and 1 Guest are viewing this topic. Read 1683 times.
orthobiz
« on: 11 Jan 2009, 04:53 pm »
Looking for a replacement belt for a Marantz 6100.
Does it matter where I buy?
Suggestions?
Paul
nrenter
Re: Are All Belts Created Equal
« Reply #1 on: 11 Jan 2009, 06:09 pm »
I just bought a replacement belt from http://www.turntableneedles.com for a Pioneer PL-A25. I could not be happier with their service.
Wayner
« Reply #2 on: 11 Jan 2009, 06:18 pm »
orthobiz
« Reply #3 on: 11 Jan 2009, 08:37 pm »
Thanks for the links.
But are all belts created equal?
I know the Marantz 6100 is an entry level machine, but I was wondering about tolerances, quality, etc. also.
Paul
Wayner
« Reply #4 on: 11 Jan 2009, 09:26 pm »
Almost all belts for these vintage machines are from a second party. I have bought at least one belt that I could feel the thickness vary with my fingers and it didn't play well. The other problem is that some belts are not the right length. I bought one from Needlewacker that was too short and pulled my suspended table too close to the spindle, causing all sorts of problems. LPGEAR seems to do a nice job and the quality is good, the price is high. But I'd rather have an expensive belt then a cheap ass one that causes problems. I at least, would not recommend buying one on ick-bay.
Wayner  :D
