External Power Supplies
0 Members and 1 Guest are viewing this topic. Read 1020 times.
Irwin
« on: 7 Jan 2009, 07:43 pm »
Some power amps and pre-amps come with external power supplies.I understand some of the benefits of this setup.I'm awaiting the arrival of a T-Amp that comes with a wall wart power supply.I'm contemplating buying a regulated power supply.Do any of you use
aftermarket power supplies,and was the investment worthwhile?
dweekie
Re: External Power Supplies
« Reply #1 on: 8 Jan 2009, 06:34 am »
Very worthwhile for T-amps.  Do you have any diy experience, or do you need a completed unit?
Irwin
« Reply #2 on: 8 Jan 2009, 09:30 am »
No DIY ability at all,I was thinking about a commercially available unit,12v 5amp.
BobM
« Reply #3 on: 8 Jan 2009, 01:38 pm »
External power supplies, if designed right, do more than just deliver the required power to the internals. There are also many different ways to go about this, and as you may suspect, each method has its demons to conquor. However, they will almost always improve things over a wall wart.
Bob
