0 Members and 1 Guest are viewing this topic. Read 6700 times.
No. Upgrade to Mac.Paul
I can't justify the move to Vista and will update my Window XP Media Ed as I wait for Windows 7, then I'll probably look for a custom builder to refurbish my HTPC with new motherboard and such. I just added 2G of RAM for a total of 3G now and I'm thinking of replacing my P4 3.0 with a pulled 3.4, the highest it goes for my motherboard. Other than that, it's a waiting game and enjoy what I got which I'm pretty happy with, thanks in large part to GHM's help with incorporating my Trends USB transporter. Cheers,robin
Something to maybe consider -- the crippled Vista audio mixer. I (and others as well) consider the Windows mixer system in Vista to be significantly inferior to the older system that XP and previous Windows versions used. Essentially the Vista mixer takes out considerable control capability that used to be there -- it does not let you easily treat the the audio system as a collection of audio hardware component sources (even though that's what it is)-- in Vista, the audio playback system is treated as a collection of application program sound outputs that all get mooshed together. Try to mix in the Line input with what a CD is playing to the speaker. Or a microphone and a line input. Or try to record what is playing out to the speaker. Try to adjust the recording level in a soundcard that has input level control (if you can find it! - or to avoid useless recording dynamic range loss from fake "software" level control in systems that don't!). Sometimes it's possible (but not usually, it seems), though it's anything but intuitive to do. Also, I can't say for sure it's Vista (never having had both OSes in the same machine) but in Vista systems I've used, the audio seems more fragile and much more likely to have data dropouts and recording problems. I wouldn't want to do professional recording with the Vista setups I've seen. And also take note of the number of soundcards that STILL don't have decent Vista drivers and the ones that do have drivers, but which prioritized DRM management (limiiting what you can do with a SPDIF output).Particularly for some of us who use soundcards as part of measurement systems, Vista audio is a near disaster. There apppears to be no way for an application to control the overall mixer, the hardware inpiuts, nor to know and restore a given mixer setting. So other programs can interfere with the hardware settings or even the actual sample rates the system uses -- bad, bad news. I sincerely hope that Windows7 restores the usability of the mixers and ditches the dumbed down audio system, but I doubt it will. The new mixer arrangement is likely to reduce customer tech assistance requests for Microsoft, since beginning users can get things to play easily for simple functions, even if they can't do much else with the audio.
Hey Robin..smart to wait on Windows 7! Nothing wrong with the newest Vista, but Windows 7 is a BEAST!! Fast !!! and decisive! This new OS is going to be a HUGE hit for windows users!! I've only been using it for the last hour... I'm already sold! I can't wait for the retail version to be released!
There is lots to read about Vistas superior audio ability here and everywhere else.
