Headshells?
0 Members and 1 Guest are viewing this topic. Read 1897 times.
chgolatin2
Headshells?
« on: 10 Dec 2008, 12:53 am »
Silly question but does it matter the headshell that is installed on your tonearm?  I have the Technics SL-1200 I went to Guitar Center and purchase a decent headshell "Stanton" brand which I was not too happy about but since I needed a headshell I went with it.  The cost was cheap, around $11 but I am not happy since is not a Technics brand yes I'm being very picky but....  You guys know we are all picky, anyway.  Does the headshell brand or type make a difference of should I just stick to good ole regular OEM?
Sorry for the newbie vinyl question...
Thanks~!
hifitommy
one of the best
« Reply #1 on: 3 Jan 2009, 08:30 pm »
in construction and value is the sumiko hs12:
http://www.needledoctor.com/Sumiko-HS12-Headshell
also available from other sources.  there are TWO retaining pins, above and below, adjustable azimuth, and the wires are premium litz that for $20 alone.  i have several of these shells and they are my faves.
theyve been discussed at length at audioasylum.com in the vinyl asylum, just search the archive.
chgolatin2
Re: Headshells?
« Reply #2 on: 7 Jan 2009, 08:30 pm »
Cool, thanks aa :thumb:
Airborn
Re: Headshells?
« Reply #3 on: 7 Jan 2009, 10:02 pm »
LP Gear is another good source for headshell options.  I believe the Zupreme is very similar to the Sumiko....
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=LG&Category_Code=HEADSHELLS
hifitommy
very likely is
« Reply #4 on: 8 Jan 2009, 01:04 am »
the idea that they are both made by jelco and are nearly identical.  in view of that, i wouldnt want to spend the extra $9 for the zu.
TheChairGuy
Re: very likely is
« Reply #5 on: 8 Jan 2009, 01:14 am »
Not that it matters much, but I think both are made by Nagaoka, not JELCO, for LP Gear and Sumiko.
John
hifitommy
good to know.
« Reply #6 on: 8 Jan 2009, 04:53 am »
i am glad there are still companies that make what we want and need.
