0 Members and 3 Guests are viewing this topic. Read 382367 times.
Yes, sounds good.Actually, I've always thought a true real time OS would be the way to go if you want to ensure highest priority for a peripheral. Jam the whole song into memory and do nothing but process that and transfer it right out the port. I used to work with and sell Intel's RMX (Realtime Multitasking eXecutive) OS many years ago and it worked great for embedded apps and shop floor control kinds of stuff we did. Very easy to use and lots of tools, even back in the day. I'm not sure what modern equivalents are though or whether it's worth the trouble but the lighter weight the better IMHO.
Oh, nice!
Interesting, so they just used the PCI slot on that MB. I suppose a nice option if you need S/PDIF or AES/EBU output. I wonder how custom the software actually is, other than running the front panel and the Bryston MPD client.
This is a great thread and thanks to Nick for the massive amount of work he's done. I've been following it for a long time but since I have several of the M2Tech hiface widgets and they have yet to produce Linux drivers I have not moved in this direction at all. But seeing the innards of the Bryston and how they fitted the ESI juli@ certainly got my attention. I have a Juli@ and a friend recently mentioned he was pulling I2S off the card. I have several old 1U T-1 to VOIP bridges which were being scrapped, I grabbed them purely for the chassis. One of those with an Alix board and a Juli@ card sending out I2S to my DAC would be interesting. Plenty of room to implement a nice linear supply in the box as well. Hmm... another winter project. I have a CF card in my IO Box and it's been sitting idle for a long time. The IO Box runs an embedded Linux as well but has a tough time with 24/192 files, just not quite enough horsepower or so it seemed.
Mike,Keep me informed on that project. I'd like to know details if you get it up and running.
Hey GuysI ordered this off of eBay:http://cgi.ebay.com/PC-Engines-Alix-2c10-kit-same-Alix2d2-Alix2d3-/280532918295?pt=COMP_EN_Routers&hash=item415110a017Showed up in 2 days and it has everything, case, PS, and 1gb CF card.I installed VirtualBox on my Windows 7 machine and Debian Linux "on" it. I also ordered a cheap CF card reader:http://www.newegg.com/Product/Product.aspx?Item=N82E16820192025My plan is to use the Debian on my computer to install Voyage via the CF reader. Hopefully it goes ok! Will keep everyone updated.-Jim
Hi, I just bought one from eBay, but after I paid, then I found out there is no SPDIF on this board, OMG, what should I do?
jeffery,This project is aimed at feeding a USB DAC only. If you want SPDIF you might want to try ordering a Alix 1d mini-itx and some sort of PCI card, lke the ESI Juli@.
Buy a USB DAC?-Jim
Ughh....so the cf card reader I ordered showed up today and the Debian install on my Windows 7 machine won't recognize it. Of course. Anyone want to help me by getting Voyage on my 1gb CF card (will send it to you)? I'd rather not try hit or miss with another (crappy) reader.Shoot me a PM if you can help.
Jim,Send me a PM.Also, what does dmesg say when you plug in the card reader. (Type dmesg 5 seconds after you plug in the card reader)
