Bryston BDP-1 Sneak Peak for Audiocircle
0 Members and 1 Guest are viewing this topic. Read 190794 times.
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
Re: Bryston BDP-1 Sneak Peak for Audiocircle
« Reply #340 on: 11 Oct 2010, 02:57 pm »
The Pearl's optical digital input for DAC mode only handles 96kHz max. The BDA-1 goes up to 11 (I mean 192kHz)!
 :evil: @*%^^*@%$... :evil:
Damn... The BDP-1 does not have an optical out. Small glitch in my plan.
Phil A
« Reply #341 on: 11 Oct 2010, 02:59 pm »
Not sure why you need the optical out but there are optical to coax converters and they are cheap
Phil A
« Reply #342 on: 11 Oct 2010, 03:02 pm »
Here is one example of such a device -  http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=2948&seq=1&format=2
srb
« Reply #343 on: 11 Oct 2010, 03:24 pm »
If you are going to get a premium digital music player like the BDP-1, which eschews convenience and network features for pure state of the art digital music playback, I'm not sure you would want to put a $12 converter (or other converter at any cost) in the mix.
While they may be fine for less critical applications like a cable box, the possibility of additional jitter and no guarantee of bit perfect output would be counter-intuitive to the purity of the BDP-1 device and signal chain.
SFOX
« Reply #344 on: 14 Oct 2010, 06:18 pm »
BDP-1 with BDA-1
james
James
When will the BDA-1 be available with the new buttons to match the BDP-1 and are any changes planned for the LEDs (will the LEDs above the source buttons still be white when the unit is in standby)
Steven
HooStat
« Reply #345 on: 15 Oct 2010, 12:02 am »
It seems like this product and the DAC could be made to work with the MPS-2.  I realize that these are supposed to be stand-alone items but it would take the power supply out of both, and make for fewer power cords.  Probably too hard to make two versions of these (with and without an internal power supply), but I thought I would bring it up.
One benefit of using these products with a Bryston preamp is that you can get some source switching that is not available on the BP26 -- for digital sources only of course.
qkot
« Reply #346 on: 16 Oct 2010, 07:28 am »
James,
What media management program are you using to organize your library/hard disk for the BDP-1?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #347 on: 16 Oct 2010, 01:14 pm »
James,
Hi gkot,
I have used Media Monkey most of the time but sometimes iTunes and Foobar as well as JRiver.
james
AGP
« Reply #348 on: 25 Oct 2010, 10:15 am »
Hi James.
When will the BDA-1 be available in Asia?
And will you have a special package price for a BDP-1 & BDA-1 combo?
Its been a bit quite on this forum did I miss something.
« Reply #349 on: 25 Oct 2010, 12:06 pm »
Hi James.
Hi AGP
We started building last week so depending on when the distributor ordered you should start to see units in a few weeks. The combo idea is something we are talking about and I am thinking of a special price as you say for both.
james
AGP
« Reply #350 on: 25 Oct 2010, 01:45 pm »
Hi AGP
james
Thanks James
I will give my dealer a call tomorrow. :D
« Reply #351 on: 25 Oct 2010, 05:16 pm »
BDP-1 BACK:
« Last Edit: 25 Oct 2010, 08:03 pm by James Tanner »
srb
« Reply #352 on: 25 Oct 2010, 05:21 pm »
It looks like your rear panel silkscreen legends for Ethernet and USB and reversed.
« Reply #353 on: 25 Oct 2010, 05:30 pm »
Yes sorry - Correct - I am getting new pictures done but I was being pushed to show the back - its an early prototype.
james
« Reply #354 on: 25 Oct 2010, 08:02 pm »
Corrected:
james
BrystonFan
« Reply #355 on: 26 Oct 2010, 01:04 am »
James,
How would one connect all four units ?
BDP-1
BDA-1
BCD-1
SP2
Thanks.
nikon
« Reply #356 on: 26 Oct 2010, 01:12 am »
James
Thank you for posting picture
What type of connectors are used for the trigger - will the production version use same connectors for trigger as amps etc
« Reply #357 on: 27 Oct 2010, 09:54 pm »
Hi Folks,
As you know we just started shipping our new BDP-1 Digital Player last week.
Please see attached first reaction from our very sonically picky distributor in Austria!
james
Von: James Tanner [mailto:[email protected]]
Gesendet: Mittwoch, 27. Oktober 2010 16:29
An: 'Edvard Potisk'
Cc: Brian W Russell
Betreff: RE: BDP-1
Hi James and Brian,
We just unpacked BDP-1 and we will connect it today later. It looks great.
Hi James, hi Brian,
I am just enjoying BDP-1 and really fantastic pure Bryston sound. Amazing!!
I also managed to control it over both PC and Iphone, I managed also to have access over mPoD. Super!
Yes, this new BDP-1 brings some new dimensions to the sound!
I can not await to show it to my colleagues.
Congratulation!! I think you will need to make enough qty shortly for all orders we will have.
Best regard
Edvard
« Reply #358 on: 27 Oct 2010, 11:44 pm »
James,
BDP-1
BDA-1
BCD-1
SP2
Hi
The BDP and the CD player (optional) would plug into the BDA.
James
1ZIP
« Reply #359 on: 28 Oct 2010, 05:12 am »
Hi AGP
james
Now we are talking my language! :)
