Bryston BDP-1 Sneak Peak for Audiocircle
0 Members and 1 Guest are viewing this topic. Read 190507 times.
klao
Re: Bryston BDP-1 Sneak Peak for Audiocircle
« Reply #360 on: 28 Oct 2010, 06:41 am »
Now we are talking my language! :)
Hope the idea will become reality and applies to international markets too.   :icon_lol:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #361 on: 28 Oct 2010, 05:17 pm »
Hi Folks,
BDP-1 Digital Player .... iPhone/Ipod Touch/iPad setup demo for Bryston MINI Interface
http://www.youtube.com/watch?v=spw4-OPLZ4I
james
BrystonFan
« Reply #362 on: 28 Oct 2010, 10:32 pm »
James,
How would one connect all four units ?
BDP-1
BDA-1
BCD-1
SP2
Hi
The BDP and the CD player (optional) would plug into the BDA.
James
Got it - but what about the BDA into SP2 ?
Would I be able to only use the BDP into SP2 via digital coax?
Thanks.
KeithA
« Reply #363 on: 29 Oct 2010, 01:50 am »
Thanks.
BDA into SP2 via analogue connects.
You could use the BDP-1 via digital coax into the SP-2, but the decoding would be done by the SP-2 processor.
Keith
OgOgilby
« Reply #364 on: 29 Oct 2010, 12:22 pm »
Hi James,
Since the recommended connection from the BDP-1 to the BDA-1 is AES-EBU, does the BDP-1 come with the correct length (short) AES-EBU cable for hooking it up to the BDA-1 when they are stacked together?
« Reply #365 on: 29 Oct 2010, 02:29 pm »
Hi James,
Hi,
Does not come with it but we do have 110 ohm AES-EBU cables available on our website.
james
OgOgilby
« Reply #366 on: 29 Oct 2010, 07:11 pm »
Hi,
james
Thanks James,
Hmmm... I was hoping for a 1/4 meter cable (or whatever the minimum length would be) from the BDP-1 to the BDA-1. It seem clunky to have to use a 1 meter cable for that connection. Any chance you will be offering a custom length 110 ohm AES-EBU cable to go from the BDP-1 to the BDA-1?
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #367 on: 29 Oct 2010, 08:44 pm »
uhm... What's wrong with going to your local hifi dealer?
« Reply #368 on: 29 Oct 2010, 09:01 pm »
Thanks James,
Hi - yes the cable is available on our website in any custom length you wish.
james
OgOgilby
« Reply #369 on: 29 Oct 2010, 09:36 pm »
Nothing, and I have a couple 1 meter AES-EBU cables laying around. I was just hoping that Bryston would have an AES-EBU cable specifically designed for the distance from the BDP-1 to BDA-1. No biggie since I haven't ordered a BDP-1 - yet  :wink:
SFOX
« Reply #370 on: 30 Oct 2010, 02:25 am »
Hi James
I placed my order for BDP-1 and 1 meter AES EBU cable today with Professional Sound
Is there a 'correct' minimum length for the digital cable or is the 1 meter length optimum
Steven
« Reply #371 on: 30 Oct 2010, 02:52 am »
Hi James
Steven
Ho Steven,
No specfic length.
james
nikon
« Reply #372 on: 2 Nov 2010, 09:20 am »
Hi James
Couple questions ...
Are you planning Bryston Nights at any other dealers in the GTA in the near future
When will literature be available for the BDP-1
Will the BDA-1 be using the same buttons as the BDP-1 and if so when approximately
« Reply #373 on: 2 Nov 2010, 10:16 am »
Hi Nikon,
No plans for more Bryston nights this year. Next stop January Vegas CES Show 2011.  I would say we are about 3 months away from the button change on the BDA-1.
I do have a preliminary 4 page literature piece on the BDP-1 in PDF if you wish.
james
« Reply #374 on: 2 Nov 2010, 11:45 am »
Inside shot of BDP-1 for those who asked.
james
drummermitchell
« Reply #375 on: 2 Nov 2010, 12:36 pm »
Jeez,another present for the wifey,definately worth it.....the wife I mean..really I do.
« Reply #376 on: 5 Nov 2010, 04:00 am »
Sent: November-04-10 10:07 AM
To: James Tanner
Subject: BDP-1 - Impressions
Hi James:
I am getting more comfortable with the Bryston BDP-1 Digital Player each day, and I'm struggling to try to explain what it has done for my audio system.
My recently-purchased Bryston BDA-1 improved the sound in all ways, as did my new Torus CS15. Better sound-stage, more clarity, more visceral -- great and easily discernible improvements.
The BDP-1 Digital Player has done something else -- it's not a dramatic, in-your-face improvement, but it's done something far more important.  If you listen carefully, each instrument, every voice, has better articulation, as if some subtle addition has been made to every note. The overall feeling is that everything is, dare I say it, more life-like, but more significantly, more musical.  It sounds better than listening to CDs. Indeed, while the sound of the high resolution (24/96) files that come with the BDP-1 is very good, it is only marginally better than the sound of files ripped from CDs into a lossless audio codec (format). In other words, there's no need to rush out and try to find high resolution files for this reason -- your digital files collection is completely transformed by the BDP-1.
I was an earlier adopter of the use of digital files played through my audiophile system. In my view, the BDP-1 is a break-through product. To use a rough analogy, even if you now listen to digital files, using the BDP-1 to play them is like going from ordinary TV to HDTV.
I'm altogether delighted and rush to my music room every day to listen to this marvelous transformation. The bottom line, and the highest compliment to Bryston, is that I really don't want to hear my digital files any other way. As for my CDs, they can continue to gather more dust.  Anyone need an extra CD player?
DW from B.C.
alexone
« Reply #377 on: 5 Nov 2010, 07:39 am »
James,
did you try a USB hub in order to use 2, 3 or even more hdd with the BDA-1? if yes, any issues?
al.
« Reply #378 on: 5 Nov 2010, 09:49 am »
James,
al.
Hi Al,
No have not tried that yet.
james
« Reply #379 on: 5 Nov 2010, 04:44 pm »
Setting Up A Dedicated Router With Bryston BDP-1 Digital Player
Set-up Instructions if you do not have a “Local Home Network” or simply wish to operate your Bryston BDP-1 Digital Player as an isolated system from other surrounding local networks.
1. Plug in your Router to a power source
2. Plug the Ethernet cable into one of the (RJ45)  ‘LAN OUTLETS’ on the rear of the router (NOT THE WAN OR INTERNET INLET) - usually there is only one ‘Wan’ inlet and 4-5 grouped ‘LAN’ outlets present on most routers.
3. Plug the other end of the Ethernet cable into the Ethernet input on the rear of the BDP-1 Digital Player
4. Turn on the BDP-1 Digital Player (will take about a minute or two to fully boot-up)
5. Open up the WEB-BROWSER on your interface (iPhone, iPad, iTouch, Computer etc.) and enter BRYSTON-BDP-1.LOCAL
6. The Bryston Web-Interface will show up and you can select either Bryston MINI or Bryston MAX interface.  Mini is designed to operate on smaller hand-held devices (iTouch, iPhone) and Max is designed to operate on larger displays such as iPads and full size computer screens.
7. The Bryston web-browser will load showing what content is present on the Bryston BDP-1
