0 Members and 1 Guest are viewing this topic. Read 11277 times.
If the only / primary weakness of the Horns that bugs you is the lack of bass, get a Pass F-1 or add the Cube. Before you part with your Horn's, make sure you first listen to whatever you intend to replace them with in your home. You may find that by fixing one problem you've created another problem. Remember, no system / component is perfect. Audio is full of compromises.
Having owned hornshoppe horns in the past I've not found a speaker with the coherency and enjoyment I had with them. I have a 17x24 room and looking under $3000. I've considered WLM, Zu, Omega. Experienced suggestions are appreciated!
