New: Super 8 Alnico XRS replaces MaxHemp as Omega’s flagship
0 Members and 1 Guest are viewing this topic. Read 6087 times.
Louis O
News from Omega...
The best just got better: Super 8 Alnico XRS replaces MaxHemp as Omega’s flagship single-driver loudspeaker
November 14, 2008
Available now priced at $3,500 a pair, Omega’s Super 8 Alnico XRS replace the MaxHemp as Omega’s flagship model.
The Super 8 XRS is a completely new speaker for Omega.
Like all Omega XRS-style speakers, the Super 8 Alnico XRS interacts with the room to extend the bass output. Built-in brass cones tilt the front of the speaker slightly for optimal soundstaging. And like other XRS models, this speaker is ‘room friendly,’ working well in a variety of room placements -- even close to corners and back walls.
This model shares design characteristics found in Omega’s smaller XRS speakers, including:
- Extended bass response
- Short cabinet heights, which virtually eliminates cabinet flex and resonance problems, translating into pure, uncluttered mids and highs
- Wide front baffles & built-in tilt, opening and broadening the soundstage
While commonalities exist, the Super 8 Alnico XRS excels compared to its smaller siblings in that it does everything they do, but better. Specifically, the Super 8 Alnico delivers:
- Greater dynamics (i.e. ‘whomp’ you can feel in your gut!)
- Better defined and more open bass response
- Improved bass texture
- Higher power handling capacity
- Greater surface area on the drivers, allowing them to reproduce more complex musical passages, while maintaining clarity and focus
According to Louis Chochos, Omega’s Founder, “relative to comparably equipped MaxHemps, the Super 8 Alnico XRS delivers improved sound quality for slightly less money.”
“For someone who wants and can afford the best Omega has to offer, this is the speaker to get,” adds Louis. Louis goes on to say “…Omega’s ultimate, no-compromise system is a pair of Super 8 Alnico XRSs matched with two DeepHemps… simply breathtaking!”
« Last Edit: 14 Nov 2008, 03:03 am by Louis O »
mca
What are the specs on this new speaker?
Alwayswantmore
Louis will be getting specs to me in the next day or two. Then the new product pages will be posted on the Omega site.  :thumb:
If you need them sooner, feel free to call.
Kent
Alwayswantmore
Hi, Louis provided specs for the new products. Here they are. Any questions, feel free to give him a call. Kent
Super 6 Alnico Monitor Specifications
Sensitivity 93dB at 8 ohms
Impedance 8 ohms
Driver Proprietary 6" Omega Alnico HempCone
Frequency Response 55-18KHz +/- 3dB (In room response to 45Hz)
Dimensions 20”H x 10”W x 14”D
Weight 30 lbs. each
Power Requirement as little as 2 watts
Cross-over  None
Warranty 10 year parts and labor for workmanship and defects
Super 6 Alnico XRS Specifications
Impedance 8 ohms
Frequency Response 44 – 18KHz +/- 3dB (In room response to 38Hz)
Dimensions 35"H x 13"W x 9"D
Weight 35 lbs. each
Cross-over  None
Super 8 Alnico Monitor Specifications
Sensitivity 93dB
Impedance 8 ohms
Driver Proprietary 8” Omega HempCone
Frequency Response 37Hz – 18K
Dimensions 23"H x 15"W x 12.5"D
Weight  35 lbs. each
Cross-over None
Super 8 Alnico XRS Specifications
Impedance 8 ohms
Driver Proprietary 8" Omega HempCone
Frequency Response 40-18KHz
Dimensions 35"H x 13"W x 13"D
Weight 48 lbs. each
Cross-over  None
