0 Members and 1 Guest are viewing this topic. Read 10679 times.
Quote from: loki1957 on 16 Nov 2008, 04:54 pmFrom what I've read about set up the cart isn't set up perfectly. Mine does the same thing at the beginning of a record and by the time it reaches the middle the in and out movement pretty much stops. The geometry changes as the cart tracks inward. Thanks for chiming in. I have a buddy who is good at this sort of thing to check my table and settings I'm mostly worried about this woofer pumping action damaging my speakers .. I will look into the filter however i've been told it does effect the sound
Where do you have your phono preamp plugged into?Wayner
What setting do you have on your Project Phono Pream, MM or MC?
I thought you were running a Denon 110.If you are running a 160, that is a MC cartridge that outputs 1.6mv.You need to switch the Project phono preamp to the MC setting and you will have higher gain. That should fix your problem.Wayner
You need to put your Project phono preamp on the MC position. The 1.6 output is too low.Wayner
You need to put your Project phono preamp on the MC position. The 1.6 output is too low.Waynerwhich ohm setting do I use if put my phono on MC Here is the specs on the Project Tube SE 2Technical data Pro-Ject Tube Box SE II Tubes 2 x ECC83 (12AX 7A) Input impedances, MM 120, 220, 340 and 440pf/47kohm Input impedances, MC 17, 18, 20, 22, 69, 100 and 220ohms/120pF Output voltage 300mV/1kHz at 3mV/1kHz (MM input) Gain, MM 40dB Output voltage 300mV/1kHz at 0,3mV/1kHz (MC input) Gain, MC 60dB Noise floor, MM 95dB (100dB - A weighted) Noise floor, MC 75dB (80dB - A weighted) THD MM 0,03% THD MC 0,1% RIAA-equalisation curve accuracy 20Hz - 20kHz / max. 0,3dB Subsonic filter at 18Hz with 24dB/octave Outboard power supply 16V/1.000mA AC, suitable for your country's mains supply Power consumption 16V/850mA AC Dimension W x H x D 103 x 72 x 158mm Weight 1.050g without power supply
