0 Members and 1 Guest are viewing this topic. Read 16524 times.
Guys, I might be WAAAAY outta line here, but have you configured your OS for optimizing audio?http://www.audioforums.com/windows-vista-optimization.phphttp://www.audiocourses.com/article309.htmlThese are just examples. A Google search will yield a plethora of choices. And while most refer to using computers as recording systems, the recommendations apply to getting rid of unwanted processes that inhibit throughput for streaming audio. Just a thought.
To put a finer point on it, my emphasis is on selecting the optimal settings in the OS, not hardware choices. Squeezecenter/Slimserver is not THAT much of a hardware hog.
Newbuyer posted below "Also, consider changing the priority of your SqueezeCenter to a higher setting and test..." I'm not certain what this is referring to. Could you explain? And/or identify what 2 or 3 optimal OS settings I should implement.
I think I will buy another GB of RAM and see what that does. Could you explain the changing the priority of SC to a higher setting? not familiar with that.Thank you,Kenreau
I believe it's not so much Squeezecenter that is slow but the web UI. Lots of JavaScript and it's just flat bloated in comparison to the older "classic" UI. The classic UI is 167KB of which 114K is JavaScript. The SC default UI is 977KB with 677KB of JavaScript, almost 6X the size of the old skin. Your browser has to compile and execute all the JS and that takes a lot of CPU cycles.Try changing the UI before you try anything else. mg
Model Brand Western Digital Model WDA4NC20000N Spec Port USB 3 x USB2.0 Form Factor 4-Bay Capacity 2TB RAID RAID 0, 1, 5 Temperature 5°C - 35 °C Features Features Small-footprint, 4-bay system Gigabit EthernetEasy setup and discovery E-mail alert system Active Directory support Push a button to transfer data from a USB driveAutomatic network backup software (for up to 3 Remote access with MioNet Download manager iTunes serverWindows Vista readyFTP server
This looks like a cool solution.QuoteModel Brand Western Digital Model WDA4NC20000N Spec Port USB 3 x USB2.0 Form Factor 4-Bay Capacity 2TB RAID RAID 0, 1, 5 Temperature 5°C - 35 °C Features Features Small-footprint, 4-bay system Gigabit EthernetEasy setup and discovery E-mail alert system Active Directory support Push a button to transfer data from a USB driveAutomatic network backup software (for up to 3 Remote access with MioNet Download manager iTunes serverWindows Vista readyFTP server Only thing that makes me weary is it is pretty new. Not a lot of feedback yet. I like the idea of having your audio stuffs on drives that can be accessed from any PC on the network without having to have one PC on all the time.
I was thinking it was a standalone NAS.
Quote from: JoshK on 15 Nov 2008, 03:32 pmI was thinking it was a standalone NAS. I guess it is...What are the advantages of a NAS versus an external HD? Im not sure.Mike
Quote from: kenreau on 13 Nov 2008, 12:45 amMy squeezecenter interface is really slow and I've been wondering what to investigate.Starting squeezecenter takes +/- 20 seconds and scrolling through the A, B, C, database sorting in annoyingly slow (several seconds). My OS and squeezecenter are on my primary drive, a 500GB (C:) drive. All my music is on another internal hard drive. I currently have roughly 600 albums, all in wav files on a 1TB internal drive (D:). It is roughly 65% full.My CPU is an Intel P-4 (with HT) 3.4 gHz something and I have 1 GB of ram. Would it speed things up if I added another GB of ram (for total of 2 GB) ? Any suggestions to speed things up would be appreciated.ThxKenreauHey Kenreau, I don't consider myself a technology expert but if I had to guess, adding some more RAM might make a minor difference but not a huge one. I would think that a lot of the slowness is due to the fact that you're playing .wav files, which are several times larger than FLAC files (which I use). How do you connect to your network with your Squeezecenter PC? Wireless or wired? Other things you might investigate are your router speed.
