Phono preamp recs
0 Members and 1 Guest are viewing this topic. Read 4726 times.
rblnr
Phono preamp recs
« on: 31 Oct 2008, 04:28 pm »
Just bought a used VPI Scoutmaster w/a Dynavector 20X low output cart. Looking for phono preamp recs under 1K, used is fine.
I love the liveliness and immediacy I often hear with tubes, so am leaning in that direction if I can find something suitable.  Tubes with balls is how I'd describe my ideal sound.
Ideas appreciated.
doug s.
  • makin' music
Re: Phono preamp recs
« Reply #1 on: 2 Nov 2008, 06:12 am »
jolida jd-9a recently got a rave rewiew at 6moons; i have never heard it, but if i were in the market, it would be on my short-list.
http://www.6moons.com/audioreviews/jolida3/phono.html
and underwood hifi offers mods; still would be under your budget...
http://www.audiogon.com/cgi-bin/cls.pl?preaphon&1230249675&/Jolida-JD-9A-Level-1-new-modif
doug s.
royphil345
« Reply #2 on: 2 Nov 2008, 07:58 am »
I have a Jolida JD-9A. I wasn't sure if it was going to work out at first, but I'm really happy with it now and I have no plans at all to upgrade. I can definitely say it's well worth the money with no reservations at all. The vinyl's been sounding pretty darn good around here lately.
The stock Chinese tubes really limit the frequency extension, both in the lows and highs, resulting overall in kind of a bright, forward sound with slightly "gritty" highs.
I tried a LOT of different 12AX7s in it, both NOS and new production. It doesn't seem to work well with NOS or the more "premium" new production tubes. There seems to be a little too much gain and the result is thin mids and exaggerated frequency extremes... a "thin" sound. I settled on using Sovtek 12AX7LPS. The frequency response is now very balanced. There's a slight richness in the mids, although this is not at all a "warm and fuzzy" sounding phono stage, the trick seems to be to get a little warmth out of it which I feel was accomplished thanks to the Sovteks. The detail and sense of "life" are very good for something in this price-range. The dynamics and  "punch" are definitely above entry-level. Having a decent amount of "tweak" settings to match just about any cartridge is really nice too, although there are phono stages with more steps to the "tweak" settings.
I don't know if I'll ever even consider the mods. I'd be afraid to ruin the synergy that's going on now.
I tried the New Sensor Mullard copies they used for the 6moons review. They look exactly like the Sovtek LPS (same company makes both) I'm using in construction, but the gain on my "Mullard" set was higher and they sounded too "thin". Don't know if I just got a set with particularly high gain or what... Although, their only real criticism was that some of them would have liked the JD-9 to sound a little richer. So, maybe they should give the Sovtek LPS a shot. Also, I've talked to a few other JD-9A owners on Audio Asylum. Some moved on to other things... One of the guys who stuck with it like I did also ended up using the Sovtek LPS and likes it a lot.
« Last Edit: 2 Nov 2008, 07:13 pm by royphil345 »
2gumby2
« Reply #3 on: 2 Nov 2008, 11:10 am »
I recommend the Bel Canto Phono Stage. I never knew my system could sound so good until I heard it through the Bel Canto.
rblnr
« Reply #4 on: 2 Nov 2008, 01:43 pm »
Thanks for the recs. -- I'll look into the Jolida and Bel Canto.
What is it you like so much about the Bel Canto -- not much info out there.  The Jolida may be right up my alley as I'm just getting back into vinyl and don't want to spend too much yet, but am leaning towards tubes.  Need to see how much use the TT will get before investing any heavier.   And there aren't to many tube choices out there below 1K that look attractive.
lcrim
« Reply #5 on: 2 Nov 2008, 02:00 pm »
After buying and selling many phonosections, I finally ended uo with a Jolida JD-9 and an Eastern Electric Minimax.  The Jolida is very flexible and has tremendous gain figures.  I also settled on the Sovtek 12AX7LPS for the tube buffers.  The actual amplification is accomplished by opamps but the tube buffering does help to smooth out the sound.  At the price level I don't think any other phono pre can touch it.
The Eastern Electric at a considerably higher price is much more refined sounding phono section.  It sets the standard in phonos under $1500.  It does not however have enough gain @ 57 dD for very low output cartridges.  My wood bodied Benz Micro Ruby 3H cartridge @  .66 mV is a terrific match.  I wouldn't recommend lower than .4 or .5 mV output cartridges with it.  The Eastern electric might be found used for a price that would fit your budget
Having written all this, I would highly recommend both phonos and they are both very well built.  I have had no repair issues w/either of them.
rblnr
« Reply #6 on: 2 Nov 2008, 02:06 pm »
Exchanged a bit of email w/Bill O'Connell who distributes the Minimax -- he's gotten feedback that it doesn't really work w/the low output Dynavector, not enough gain.
Brown
« Reply #7 on: 2 Nov 2008, 03:11 pm »
Ideas appreciated.
You might consider the Dynavector phonostage, makes sense if you like the cart. If your handy the Audio Note kit is quite something.
TheChairGuy
« Reply #8 on: 2 Nov 2008, 03:50 pm »
rblnr,
I stand in contrast with many vinyl-phools on this subject....I can't really recommend any phono stages.
I've yet to hear an 'adjunct' piece of phono amplification, be it phono pre or head amp in the loop, that hasn't subliminated vinyl sound.  Whether it's the extra length of interconnect, or additional rca joints, the eeny-weeny cartridge voltage gets changed to an extent that it's vitality is sapped from it  :(
Running a high output MC (or MM, if that's your speed) into a full featured preamp is what I suggest.  Your sonicflare bio wouldn't open for me, so I couldn't see what you're running now to to suggest anything in specifics.
Vinyl can sound quite flaccid as it has considerably less dynanic range than 'digital' technologies...whenever I've added an intermediary to the vinyl chain after the turntable itself, I find that immediacy and dynamics get hurt (so long as there is enough gain at the full featured preamp to fully flesh out cartridge at hand).
Anyhow, food to some additional thought....regards, John
royphil345
« Reply #9 on: 2 Nov 2008, 03:52 pm »
I'm aware the Jolida is a hybrid including high quality op amp gain stages. But, given the amount of gain this thing has, I'd have a hard time believing the tubes aren't also a gain stage. Also, the tubes are 12AX7 dual triodes. I believe only one 12AX7 would be required for a buffer stage as in the Bellari unit.
doug s.
  • makin' music
« Reply #10 on: 2 Nov 2008, 05:21 pm »
stand-alone tube buffers can run one tube or two, depends on the design - i have both.  and, the gain of each is only 1db...  so it's extremely possible the jolida's tubes are buffer only...  of course, it would be easy enough to ask jolida about it...   :wink:
doug s.
royphil345
« Reply #11 on: 2 Nov 2008, 07:10 pm »
doug s.
95 dB of gain with a 100 dB SNR?  I'd put my money on more gain stages than average... http://www.jolida.com/catalogue/models/jd9a.shtml
doug s.
  • makin' music
« Reply #12 on: 2 Nov 2008, 07:31 pm »
doug s.
i checked jolida's site - no clue as to where the gain is coming from.  as i said, only way to know for sure is to ask 'em directly.
doug s.
2gumby2
« Reply #13 on: 3 Nov 2008, 11:01 am »
It's as though a veil was lifted from my turntable. The sound is fuller, more detailed, more pleasant, and rivals CD playback. Until I got the Bel Canto, I always considered vinyl to be an inferior playback medium. After the Bel Canto, I started buying LPs again. Completely changed my attitude toward vinyl playback. Also, the Bel Canto has adjustable resistive and capacitive loading to better mate with your cartridge. It works fantastic with my Grado cartridge.
trout2
Graham Slee Era Gold V
« Reply #14 on: 5 Nov 2008, 02:33 pm »
Bought one last week and it has transformed my system. $1000 @ Music Direct w/a 30 return policy.  Give it a shot.
royphil345
« Reply #15 on: 9 Nov 2008, 12:08 am »
doug s.
doug s.
Jolida doesn't seem much for detailed answers, but here's their reply...
gain
----- Original Message -----
To: [email protected]
Sent: Sunday, November 02, 2008 4:11 PM
Subject: Question abbout JD-9A phono stage...
Hi,
Just wondering if the tubes in the JD-9A are a gain stage or a buffer stage?
XXXXXXXXXXXX
I've read many posts in many forums about the 12AX7s in the JD-9A being a buffer stage. Just another example of what happens on the internet when one person pulls some "information" out of thin air and a few others start to parrot it. Anyway... I've found it to be a fine sounding piece of gear. Wasn't so sure at first, but it's been making me extremely happy with the Sovtek 12AX7LPS installed and I'm glad I stuck with it. It has everything I was looking for... A good moving coil section with adjustable loading and capacitance, better dynamics than entry-level, better accuracy than entry-level and even a little warmth and "refinement" after finding the right tubes. I've lived with it for awhile now and I very honestly think it's quite a value for the price.
« Last Edit: 9 Nov 2008, 10:54 am by royphil345 »
dangerbird
« Reply #16 on: 9 Nov 2008, 06:03 am »
here's a thread from another forum regarding the Jolida/gain
http://www.polkaudio.com/forums/showthread.php?t=61759&highlight=jolida+phono
royphil345
« Reply #17 on: 9 Nov 2008, 08:15 am »
You'll notice I posted on that one some time ago towards the end...
Just another useless thread where another person unfamiliar with the Jolida posted that the gain specs can't be correct and that the SN ratio at the stated gain can't be correct.
As I stated there, the Jolida has so much gain the non-reduced outputs can't even be used with a low-output MC and an active preamp or receiver. They might work well with a passive preamp. I imagine the posted specs are for these rarely used, high level outputs with insane gain and the specs sure seem close enough to correct to me... I would also imagine the low noise is due to the Jolida having 3 gain stages as opposed to the usual 2. More gain stages = less noise. There are amps that put out 200+ watts per channel with a similar SN ratio, so it's certainly not impossible.
Not even sure why anyone would post a link to that confusing thread, but there's my take on it... For some reason, there's so much misinformation out there on this particular piece of gear. Never seen anything like it... I guess because it's designed a little differently than what people are used to and some feel the need to make it "fit the mold", without having any "hands on" experience with the JD-9A.
pt109
« Reply #18 on: 9 Nov 2008, 11:44 am »
The Dynavector P-75 is a no-brainer with the DV-20.  If you prefer tubes, check out the EAR 834p.
Both are great buys at their respective price points.
Hope this helps.
stevenkelby
  • Adelaide, South Australia
« Reply #19 on: 9 Nov 2008, 01:19 pm »
Well I'm glad they did!
Quote from: BaggedLancer
Just got off the phone with Walter at underwood hifi...he has tested the Jolida and found the gains to be 40, 55, and 70. He also said he tried to have a conversation with Michael Allen about it and it was like talking to the wall. Allen is convinced it's 95 db and won't change his statement.
Good to know. I haven't heard one and I'm sure it's a great piece of gear but there is a basic contradiction there somewhere...
Is Walter or Allen lying? Or is there something we don't know? If so, what?
Fair questions IMO.
Quote from: mulveling
However, the gain on a phono stage is of particular importance to insure the right voltage range for a particular system, and botching that number is a pretty big problem.
Ignorance is no excuse.
Id love to get my hands on one and at least measure the output voltage at high gain. Anyone have a JD-9A and a multimeter?
