0 Members and 1 Guest are viewing this topic. Read 13782 times.
I GIVE UP!
Quote from: es347 on 31 Oct 2008, 03:02 pmI GIVE UP!Hi -- I sent you a PM earlier but I think you are doing everything right EXCEPT getting the pointer to the image correct. It is somehwat counterintuitive but do not insert the URL for the pic, which even though you can use that to open the image in another window, is NOT what is required here. You need to find the appropriate address from the properties. So, check your text and see e.g., if you are using something like this: http://www.audiocircle.com/index.php?action=gallerysearch&cat=0&pos=3 tag then that is not going to work, you have to find the location pointer in this form: http://www.audiocircle.com/gallery/albums/userpics/49419/system_left_side.JPG -- You can find this by checking the properties of the image (see the PM for a pointer or go to http://www.audiocircle.com/index.php?topic=40968.0 for detailed instructions for the many frustrated users who have experienced this problem -- my self included I am a Mac user and do it by using option and a mouse click, I believe Windows users employ the right click....Here I will try it with one of your images as in:
Freakin' awesome. After looking at those pics I just decided I will listen to Aja in its entirety tonight.
Great looking setup Can you tell us what turntable you have there?
