Audio/Video Gear and Systems
The Lab
sts9fan
Not very happy
Not very happy
0 Members and 1 Guest are viewing this topic. Read 1818 times.
lord_glum
Not very happy
8 Oct 2008, 12:30 am »
I'm a little peeved....yonder project is not turning out how i would like. First i couldn't get the color (gray) to turn out. I wanted copper but the copper looked uber cheap. then the chassis layout was a bit tighter than i planned and had to move the pot. then the chassis punching was a bit off. eyeballing it didnt' work as well as it used to....just generally flustered at the moment and I am venting.
BTW, its a ray koonce timebandit 2A3 w/the giant hammond power transformer and electraprint outputs and chokes. sovtek outputs etc...
thanks,
Jvo
BillB
Re: Not very happy
8 Oct 2008, 12:49 am »
Man, I have days where everything I do either fails or ends up looking like crap.
Take a couple days off until you get the urge to work again.
BTW it looks great...we are our own worst critics you know.
JimJ
Ut Prosim
Re: Not very happy
Reply #2 on:
14 Oct 2008, 12:17 am »
Looks great so far, I know what that feeling is like, sometimes stepping away from a project saves me from throwing it out the window
When you come back to it, usually you have a different perspective on things...
lord_glum
Re: Not very happy
Reply #3 on:
14 Oct 2008, 12:37 am »
It got taken apart, sanded down and re-coated. Its copper now. I also hit the walnut with some steel wood and put another coat of poly on it. it is more to my liking now. it weighs around 15 to 20 pounds with all the iron.
Jvo
Niteshade
Tubes: Audio's glow plug. Get turbocharged!
Re: Not very happy
Reply #4 on:
14 Oct 2008, 01:00 am »
Everybody has days like that. The Facts O' Life!
How would you like this: I once painted an enclosure the wrong color and decided to repaint it. Sounds easy enough- until ALL the paint started to bubble up!!!! ARGH! Ohhh...lots of putty knife & sanding work!
It bubbled due to the first unwanted layer having poor metal adhesion. FYI: It didn't bubble up until it was re-sprayed.
lord_glum
Happier
Reply #5 on:
14 Oct 2008, 01:44 am »
Here is the latest update....now the chassis layout is done its time to start the real work.
The Lab
sts9fan
Not very happy
