0 Members and 1 Guest are viewing this topic. Read 8812 times.
I know nothing about electricity, but doesn't it make sense given how much juice your Atma-Sphere amps and the Aleph J in Class A would consume?
The DCX only consumes a few watts, not enough to count and I suspect the transporter isn't too bad as the only real current draw is the tube filaments. It's the amps of course that are sucking a lot. So if each Atma-Sphere is 500W and the Pass clone is drawing 200W the total is 1200 which at 120V is 10 amps. A 15A circuit likely uses 14GA wire and a 100ft run would drop about 6V with a 10A load and of course yours is much higher. My guess is a poor connection in the branch circuit. Often the outlets are daisy chained using the (IMO) crappy push in connections. I've had similar problems and replacing all the outlets in the chain took care of it. $25 well spent at the home center. A short article on this. http://www.psihq.com/iread/faqvolt.htm
especially if you are back stabber outlets upstream.
And Jerry whats a coffee maler? LOLSteve
move your "dedicated" audio circuit to the top position on the buss bars, just below the mains.
