0 Members and 1 Guest are viewing this topic. Read 85060 times.
I am curious if this was simply just a model or if you had built and measured one.
However there is one major point I wish to pick up on - efficiency/sensitivity.Yes parallel AE drivers will perform well on OB with the more sensitive widerange drivers, but they will need greater,and thus separate amplification of say 250W, whereas 2x Alpha will be fine with just a single 50W amplifier driving everything.
I agree with Martin that the low Fs is wasted - and a similar AE driver would actually perform better on an OB with Fs a little higher, say with a lighter cone. If LF power is available I would suggest choosing a driver with an Fs circa 25Hz; if not 30 to 40Hz is a good start.I also agree with Martin that once you get to 15" you can get satisfactory 'in-room' LF listening levels without needing more than say 4mm of X.max, especially with paralleled drivers. Of course we need to be realistic about desired as opposed to satisfactory listening levels.
Further to this discussion, I would suggest that the AE driver sound will not integrate as well as an Alpha with a widerange on an OB, and that using 2 in parallel will not improve this aspect.
My results are from my MathCad models. I have modeled dipole designs and correlated the results using measurements taken after building the systems. Others have done the same using my worksheets. I consider the calculated results to be validated based on these correlations.Martin
I agree with Martin's choise of woofers. System is designed for music listening in regular home environment.All 15in 20mm xmax woofers are way overkill for home stereo, unless you have really huge living space.Only reason I would get hi end 15in woofer is it's attractive looks. If speaker is used in main living room, it must look good.
using multiple amp channels and something like the DCX2496 for processing. Another nice thing is that in the active system you can passively flatten the impedance curve first. Then work with your xover and EQ. You can end up with a nearly resistive load to each channel of amplification.
Interesting. How does one passively flatten the impedance curve first?
I'm going to be putting together a full dipole system soon. I'll be using the pair of Dipole15's for the midbass section, our new 6.5" midrange driver, and possibly a B&G Neo3 for the tweeter section with the back cup removed. I'm planning a flat front baffle with wings going back on each side. A U baffle from above. If looking at the pair from the center of the room, the outer vertical edges of the baffle will have a 3" radius and the inner will have a 6" radius. Total depth will extend to about 15" on the bass section. Is this something you can accurately model? If so, can you tell me at what distance I would need to place the mic to get measurements to correlate with your models?
What kind of driver you need is clearly defined by the clean output levels you want to achieve. This formula back calculated from a Linkwitz formula tells how much displacement you need for a given SPL at a given frequency:Max SPL (at freq f) = 48.4 + 20 log (Vd x f^2), where Vd is the Sd x peak-peak Xmax in liters.Plugging in 30hz and saying you want 110dB SPL you get 1.3358L of displacement required. Now say the baffle you are choosing makes your response 10dB down at 30hz. You now need to calculate for 120dB levels. This requires 4.22L of displacement to reach your goals on the given baffle. Each Dipole15 at 12mm Xmax displaces 2.06L peak to peak, so a pair on this baffle would roughly reach this goal. This keep in mind is 110dB at 1m. If you want 110dB at 2m, 4m, etc you are subtracting 6dB per doubling of distance and upping the displacement requirements.
I think we have had a similar discussion before. I am not doubting your formula or calculations but we should all recognize that the results are correct if a pure 30 Hz sine wave is being reproduced. For a music application where the bass is composed of many different low frequencies I am not convinced that the summed displacement for a given volume level is as high as you are reporting. I have played my Lowther OB system at very high volume levels and the Eminence Alpha 15A woofers barely move even for bass heavy material. A system playing music that hits 110 dB levels is probably not all bass frequencies. I still believe that these types of calculations are extremely conservative and that the maximum deflections caused by most music playing at these volume levels will be much lower for a bass driver(s) crossed over to a mid range driver at about 200 Hz.
Just a quick comment of excursion requirements. My experience indicates that (for music) what I call the volume-separation product, VSP, should be a minimum of 33,000 cm^4 for a dipole type woofer system.VSP = N x Sd x Xmax X D where N is the number of drivers, Sd and Xmax are in cm, and D is the effective separation (Length of an H frame, effective radius of a baffle, etc. Xmax is the linear, one way (not peak to peak) max excursion.Based on this, a 15" driver with Sd about 900 cm^2 in 41 cm (16") H frame would need to have about Xmax = 9 mm (one way, not peak to peak).
John, I don't know where you got the formula for SPL but I can not be correct because it does not include the dipole separation and must vary as F^3 for a dipole. The equation I come up with is
ALso, are you saying the IB 15 has an Xmax of 18 mm peak to peak? I had interpreted that as one way (i.e.36 mm p-p).
