0 Members and 1 Guest are viewing this topic. Read 85010 times.
I plan to build two systems and would appreciate any comments. I have all the drivers in hand.System 1Alpha 15A in H frame powered using a Parts Express plate ampElectrovoice SP12B running full range. Should I add a low pass filter?Electrovoice T35 tweeter with 1st order high pass using a 2uf cap.System 2 - passive solutionAlpha 15A in H frame with 125 hz low pass filter as suggested by MJKFostex FE166ES-R with 200 HZ high pass filter and 6 olms of series resistance to address the mismatch in driver efficiency. I also plan to add an L-pad to allow it to be fine tuned.Using a plate amp for Fostex system didn't seem to make sense since the Fostex would not go low enough on the baffle to mate with the Alpha 15A when using the available low pass filter on the amp.The H frame would be interchangeable. The top baffle would sit on top of the H frame. I am a noob so please keep it simple. Thanks for the help.Bill
Hmmmm????
Quote from: panomaniac on 18 Nov 2008, 06:46 pmHmmmm???? one plate amp for each speaker, w/o waste of connections and power.
Sorry, I still don't follow....All the plate amps I've seen are mono. They do have 2 connections, tho - to mix left & right. Is that what you mean?You just use one for mono - works fine. I've run one for each speaker before, no problems.
I would only consider it a "waste of power" if the plate amps (or whatever amp) are larger than needed. That's why I advocated the use of 2 inexpensive plate amps (those PE 70 watt-ers would be fine) that total in cost to less than a typical boom-maker plate amp. Cost of extra connections is negligible, unless one chooses esoteric line-level connectors. Any connector that lets the electrons do their thing is sufficient for this case.--Tubamark
Cool - I think that some of the Augie users are running their plate amps pretty low, like 40~50Hz. Then boost it a lot. You might try that. Worked well for me with my Selenium 15s on OB.
