0 Members and 1 Guest are viewing this topic. Read 5316 times.
A good power supply is IMO mandatory in either case. Then you just have to decide if you want an external DAC or not along with the associated cabling, potential SPDIF impedance issues, etc. in exchange for upgradability, etc.Bryan
Buy an Acopian linear Power Supply and hook it up to a top flight dac. The Bryston BDA-1 is an excellent choice. Other choices are the Benchmark Dac1 or the Bel Canto Dac 3.
Thanks for the feedback.I already have two linears powering my Duet receiver which has been upgraded by Pat.mcullinan- can you connect the Bryston BDA-1 directly to an amp and control volume and balance?
Quote from: mr_bill on 22 Aug 2008, 09:57 pmBuy an Acopian linear Power Supply and hook it up to a top flight dac. The Bryston BDA-1 is an excellent choice. Other choices are the Benchmark Dac1 or the Bel Canto Dac 3.mr_bill which one of these did you use for your setup? I've got an SB3 that I'd like to change out the power supply for.Thanks
Quote from: Spidey9534 on 25 Aug 2008, 07:11 pmQuote from: mr_bill on 22 Aug 2008, 09:57 pmBuy an Acopian linear Power Supply and hook it up to a top flight dac. The Bryston BDA-1 is an excellent choice. Other choices are the Benchmark Dac1 or the Bel Canto Dac 3.mr_bill which one of these did you use for your setup? I've got an SB3 that I'd like to change out the power supply for.ThanksI used the Acopian 9V 0.5amp for the Duet. The SB3 is a 5V I believe and would need a different PS.
For that kind of price range, I would certainly check out Paul Hynes' offings ( www.paulhynesdesigns.com ).Paul is a great guy to deal with and is very knowledgeable and willing to help! I have two PSUs which feed my Altmann Attraction DAC and SB3 with supreme results!Best RegardsDennis
