0 Members and 1 Guest are viewing this topic. Read 39229 times.
Chris,Couple more questions:Amplifier raw power aside, was there any particularly noteworthy tonal synergy with any of the amps -- specifically did the EL84, EL34, 300B or 2A3 stand out in terms of overall presentation and/or synergy with the F120A?Can you also say a bit more about the sonics of the speaker in terms of resolution, tonal balance, bottom and top extension, etc.?And last but not least, how big was the room you were listening in?Thanks,Jim
Aye, that's certainly a factor - my little room is so small ......(OK, chris, how small is it?).... you need to step outside to change your mindBa-da-bumpActually, it's a converted bedroom, approx 220sq ft - of which 20% is an alcove at one end were the equipment stands and spare speakers are located (at last count 5 pairs in the room)Sounds like my officeexcept it's only 140 SF and has two pairs of speakers (unless you want to include the Heresys that are in their boxes and waiting for me to make up my mind what to do with them.The next session this weekend will be in a much larger space at Dave's - for both some measurements, and more critical test of listening. I think few of us possess "perfect" listening rooms, but this space tends to get in the way far less than any other we have readily available. Approximately 400sq ft, open plan - it's the lofted ceiling from 74" to over 16ft that makes for a calculated 350cubic meters of air - that's approx 7.5 times the volume of my room. That's very close to what I have except with a constant 9' ceiling and two large stairwell openings. That sounds like it will much more closely approximate my space.Regarding the amps , to make it short, the Mono7's were by a clear margin the most synergetic match of this group. The session also reaffirmed my personal predilection for moderate powered DHT's, although now doubt higher powered SETs (transmitter tubes, etc) could likely also float my boat. On the few occasions that I've heard such big-bore single-strokers (i.e. at VSAC shows) , it's always been to demonstrate just how effing loud the system can play. My hearing is already severely damaged / deteriorated - I don't need to further the degradation.Well actually, top candidate right now is 6c33c based (not Lamm ML 2.1s though .)So, in other words, as much as I loved the sound of the Carina, and other low powered EL84 SE amps I've heard from the Decware Zen to the Glow, I suspect that the F120A & FX120 will need more torque than that to get the job done in anything but a small space and at modest SPL's, but as always, YMMV. how's that for equivocation?
Chris, Was your modded Scott amp among the cited amps? I know that I thought they were very good the last time I heard them up on "The Mountain." I have no doubt that the Mono 7's also sounded good. The Wright Sound products have always been highly regarded for sound AND value, although they don't get as much press as they deserve.Will we be hearing this combo in August?Best Regards,TerryO
Is the F120A still available?
Three or four years back Fostex had stopped importing the F120A to the U.S. and were considering the same for the F200A.
Quote from: JLM on 14 Jul 2008, 06:01 pmIs the F120A still available?Madisound still has both the F200 and F120 on their website.
chrisby,Could you please link/define "Purvinized"?
I investigated flea amps for a couple of years, but got fustrated by the lack of affordable, uncolored speakers that could provide a "full range" sound (sufficient deep bass for music) and still be efficient enough to mate with a couple of watts.
And I'm a "speaker guy" so eventually went back to building a system around speaker ideals. The ability of the F200A to reach deep and have such rich tone for still a half-way reasonable price is what lead me to them.
