0 Members and 1 Guest are viewing this topic. Read 39240 times.
Chris, as Bud is making your iron, be sure to have the primary wound for 3.5K. I also like the flexbility of an 8- and 16-ohm secondary (the D5nf is a 16-ohm driver). I've done a ton of testing with over 30 2A3 tubes (all NOS) and I tend to get 4-watts minimum... the better ones 4.5-watts and very low distortion, generally less than 0.5% at 1-watt. I think you're retrofitting a pair of existing amps, right?? Regards, KM
Right now it's running with JJ KT-88s, some NOS RCA 0D3s, some cheap Ruby 5u4g rectifiers, and some new production 6n1ps for drivers. I can only imagine what a bit of tube rolling will bring. Source is the still breaking in RWA Isabellina (soon to go in for the full upgrade to Isabella and headphone amp.)
Thanks for the tip. How's the little guy with the Horns?
The low damping factor was a concern, but somehow, between the alnico driver, and the aperiodic cabinet, it just works.
The low damping factor was a concern, but somehow, between the alnico driver, and the aperiodic cabinet, it just works. snip... -- Jim
congrats, Jim - it sounds like the 'steens are finally able to show you what they're made of
Quote from: chrisby on 17 Nov 2008, 07:59 pmcongrats, Jim - it sounds like the 'steens are finally able to show you what they're made ofsnip... Hmmmm.... wood, glue, wool, funny dots, felt... oh, and a F120A.... and some wire. Regards, KM
Chris.... I'll go with the craft and some luv... I'm a little too old to believe in magik! In any case, very nice work... you earned it. Regards, KM
