0 Members and 1 Guest are viewing this topic. Read 3639 times.
One thing to keep in mind about toroid's. If there is any DC on your power line the transformer will audibly buzz and the magnetizing current will go up. This is because they have no air gap. EI transformers have an unintentional air gap of about .001 inches. That's all it takes to keep a transformer happy with a volt or two on the line. If size is not an issue you will do better with a standard EI transformer.Because I am an inquisitive person I peek inside amplifiers from time to time. What I note is what once was very rare (toroid power transformers) is now common. They appear in almost all prosound amps which sell at ridiculously low prices compared to high-end amps. They give the maker the advantage of a slim case though is some cases that advantage is not taken. They must have gotten very inexpensive as they became more popular.Now my question for you and others: What is the fascination with Cryo'd connectors, wire, tubes, etc, etc? How would you know if it was done or not.
Hi,I hear that cryo treatment is done by the pound and it's not at all expensive if you go to the guy who has the equipment. If you had your CD player modified by Ram Labs, it must have been some other Ram Labs. I tend to leave others designs alone, it's their work so let it stand on it's own.
Because I am an inquisitive person I peek inside amplifiers from time to time. What I note is what once was very rare (toroid power transformers) is now common. They appear in almost all prosound amps which sell at ridiculously low prices compared to high-end amps. They give the maker the advantage of a slim case though is some cases that advantage is not taken. They must have gotten very inexpensive as they became more popular......
Quote from: Roger A. Modjeski on 8 Jul 2008, 10:52 pmOne thing to keep in mind about toroid's. If there is any DC on your power line the transformer will audibly buzz and the magnetizing current will go up. This is because they have no air gap. EI transformers have an unintentional air gap of about .001 inches. That's all it takes to keep a transformer happy with a volt or two on the line. This is true, especially as the VA increases, and also with core undersizing. But that is dealt with with a simple[search on] 'dc blocker', 4 diodes and a pair of electrolytics.
